** Changed in: epics-base
Status: In Progress => Fix Committed
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1908305
Title:
Default DTYP can be changed by DBD file order
Status in EPICS Base:
Fix Committed
Bug description:
Kay Kasemir reported:
I was always silently expecting that a record from a *.db file that
doesn't specifically list the DTYP would default to "Soft Channel".
Example:
record(ai, "XXX")
field(INP, "SomeOtherRecord")
just works because the field DTYP="Soft Channel" is the default.
Now I notice that at least with R7.0.3.1, the default is not "Soft
Channel" but whatever is listed first in the *.dbd file. If that file
looks like this:
device(ai, CONSTANT, devAiSoft, "Soft Channel")
device(ai, INST_IO, devAiXXXX, "MyDeviceSupport")
then the default for an ai record DTYP is indeed "Soft Channel".
But if I put "MyDeviceSupport" on top, that becomes the default, as
can happen when you change the order of XXX_DBD file entries in the
Makefile.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1908305/+subscriptions
Build completed: EPICS Base 7 base-7.0-177 AppVeyor via Core-talk
[Bug 1907077] Re: errRawCopy formats S_dbLib_badField as "Error (512, 512)" Andrew Johnson via Core-talk
<2021>
2025
2026
[Bug 1908305] Re: Default DTYP can be changed by DBD file order Andrew Johnson via Core-talk
<2021>
2025
2026
