2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: [Bug 1907077] Re: errRawCopy formats S_dbLib_badField as "Error (512, 512)"
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 01 Mar 2021 04:22:01 -0000
** Changed in: epics-base/7.0
       Status: Fix Committed => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1907077
Title:
  errRawCopy formats S_dbLib_badField as "Error (512,512)"
Status in EPICS Base:
  Fix Released
Status in EPICS Base 7.0 series:
  Fix Released
Bug description:
  Problem:
  errRawCopy formats S_dbLib_badField as "Error (512,512)" while it should format it as "Error (512,11)".
  Scenario:
  1) Create a DB with the following record:
  record(lsi, "lsiRec")
      field(SIZV, "256")
      field(VAL, "initial value")
  2) While loading the DB, EPICS will print the following error:
  Can't set "lsiRec.VAL" to "initial value" Error (512,512)
  Potential Cause:
  Line 135, libcom/src/error/errSymLib.c:
  epicsUInt16 modnum = (statusToDecode >>= 16) & 0xffff;
  Solution:
  Replace 135, libcom/src/error/errSymLib.c with:
  epicsUInt16 modnum = (statusToDecode >> 16) & 0xffff;
  Severity:
  This problem makes troubleshooting EPICS DB issues harder.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1907077/+subscriptions
Prev: [Bug 1899697] Re: PHAS is not always respected when SCAN=Event Andrew Johnson via Core-talk
Next: [Bug 1908305] Re: Default DTYP can be changed by DBD file order Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: [Bug 1907077] Re: errRawCopy formats S_dbLib_badField as "Error (512, 512)" Andrew Johnson via Core-talk
Next: [Bug 1242919] Re: caget of an empty waveform record returns 2.50321e-308 in 1st element Andrew Johnson via Core-talk
ANJ, 28 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
