2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: mp+394327 at code.launchpad.net
Date: Tue, 02 Mar 2021 21:50:08 -0000
To expand, I take it you're referring to the change which replaces
> osdPosixMutexInit(&spin->lock, 0);
calls with
> osdPosixMutexInit(&spin->lock, PTHREAD_MUTEX_DEFAULT);
Where RTEMS 5 has
> .../include/sys/_pthreadtypes.h:#define PTHREAD_MUTEX_DEFAULT    3
This is a simple enough change, and the exact timetable for RTEMS5 support is uncertain enough to me, that I think it should be applied on 7.0 soon.  Do you (ANJ) want to do this?  If not, then I will.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/394327
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Brendan Chandler via Core-talk
Prev: Re: epicsTypes.h question Johnson, Andrew N. via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Brendan Chandler via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 02 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
