2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0
From: Brendan Chandler via Core-talk <core-talk at aps.anl.gov>
To: <core-talk at aps.anl.gov>
Date: Tue, 2 Mar 2021 15:54:08 -0600
FYI this is in my RTEMS5 pull request:
https://github.com/epics-base/epics-base/pull/105/commits/79242da5156856a3caf98bc02f371defaab4cfc3
On 3/2/21 3:50 PM, mdavidsaver via Core-talk wrote:
To expand, I take it you're referring to the change which replaces
osdPosixMutexInit(&spin->lock, 0);
calls with
osdPosixMutexInit(&spin->lock, PTHREAD_MUTEX_DEFAULT);
Where RTEMS 5 has
.../include/sys/_pthreadtypes.h:#define PTHREAD_MUTEX_DEFAULT    3
This is a simple enough change, and the exact timetable for RTEMS5 support is uncertain enough to me, that I think it should be applied on 7.0 soon.  Do you (ANJ) want to do this?  If not, then I will.
Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 mdavidsaver via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
ANJ, 02 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
