2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository
From: junkes via Core-talk <core-talk at aps.anl.gov>
To: joel at rtems.org
Cc: Core talk <core-talk at aps.anl.gov>, "rtems-devel at rtems.org" <devel at rtems.org>
Date: Wed, 03 Mar 2021 18:09:59 +0100
In file included from ../../bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c:1:
../../bsps/powerpc/beatnik/net/porting/rtemscompat.h:164:2: error: #error rtemscompat_defs.h must define either NET_CHIP_LE or NET_CHIP_BE
164 | #error rtemscompat_defs.h must define either NET_CHIP_LE or NET_CHIP_BE
Hopefully this is fixed by adding the include directory or something
similar.
 Vijay should speak up on his desired solution.
Heinz, how did the code find this when it was built in the tree? Did it have
a -I for this source directory?
--joel
8:04:57 runner ['/home/junkes/MVME6100_testing/rtems/6/bin/powerpc-rtems6-gcc', '-mcpu=7400', '-I/home/junkes/MVME6100_testing/rtems/6/powerpc-rtems6/beatnik/lib/include', '-MMD', '-I.', '-I../..', '-Iinclude', '-I../../include', '-I../rtems/6', '-I../../../rtems/6', '-Itestsuites/include', '-I../../testsuites/include', '-I../rtems/6/include', '-I../../../rtems/6/include', '-Ibsps/include', '-I../../bsps/include', '-I../rtems/6/powerpc-rtems6/beatnik/lib', '-I../../../rtems/6/powerpc-rtems6/beatnik/lib', '-I../rtems/6/powerpc-rtems6/beatnik/lib/include', '-I../../../rtems/6/powerpc-rtems6/beatnik/lib/include', '-Ibsps/include/libchip', '-I../../bsps/include/libchip', '-Ibsps/powerpc/beatnik/net/porting', '-I../../bsps/powerpc/beatnik/net/porting', '../../net/radix.c', '-c', '-o/home/junkes/MVME6100_testing/legacyNet/build/powerpc-rtems6-beatnik/net/radix.c.2.o']
Heinz
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository junkes via Core-talk
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Joel Sherrill via Core-talk
Prev: [Bug 1902560] Re: Read info items using a filter Dirk Zimoch via Core-talk
Next: Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Vijay Kumar Banerjee via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Joel Sherrill via Core-talk
ANJ, 03 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
