On Wed, Mar 3, 2021 at 12:37 PM junkes <junkes at fhi-berlin.mpg.de> wrote:
> Hi Vijay,
> I tried it again:
Hi Heinz,
I'm really sorry that the build crashed again. I missed the telnetd.h
file probably because it was somewhere in my build prefix from one of
the rtems builds. I have pushed a fix on the rtems repo and the
rtems-net-legacy repo. This time I was more thorough and used a new
prefix location, I believe it won't break this time.
Thank you for helping with the testing. I really appreciate it.
Best regards,
Vijay
> # building kernel
> #git clone git://git.rtems.org/rtems.git kernel
> git clone git://git.rtems.org/vijay/rtems.git kernel
> cd kernel
> git checkout devel-no-libnet
> # build and install bsp
> # 1. Test with waf
> #-e "s|RTEMS_NETWORKING = False|RTEMS_NETWORKING = True|" \
> ./waf bsp_defaults --rtems-bsps=powerpc/beatnik > config.ini
> sed -i \
> -e "s|RTEMS_POSIX_API = False|RTEMS_POSIX_API = True|" \
> -e "s|BUILD_TESTS = False|BUILD_TESTS = True|" \
> config.ini
> ./waf configure --prefix=/home/junkes/MVME6100_testing/rtems/6
> ./waf
> ./waf install
> cd ..
> # building extra legacy net
> git clone git://git.rtems.org/vijay/rtems-net-legacy.git legacyNet
> cd legacyNet
> git submodule init
> git submodule update
> ./waf build --rtems-archs=powerpc --rtems-bsps=beatnik
> Much better, but still a missing file?
> [125/235] Compiling libc/res_mkquery.c
> [126/235] Compiling libc/inet_lnaof.c
> [127/235] Compiling librpc/src/xdr/xdr_array.c
> ../../telnetd/check_passwd.c:70:10: fatal error: rtems/telnetd.h: No
> such file or directory
> 70 | #include <rtems/telnetd.h>
> compilation terminated.
> ../../telnetd/telnetd.c:57:10: fatal error: rtems/telnetd.h: No such
> file or directory
> 57 | #include <rtems/telnetd.h>
> Waf: Leaving directory
> `/home/junkes/MVME6100_testing/legacyNet/build/powerpc-rtems6-beatnik'
> Build failed
> -> task in 'network_objects' failed with exit status 1 (run with -v to
> display more information)
> Heinz
- Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository junkes via Core-talk
- Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Heinz Junkes via Core-talk
- Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Joel Sherrill via Core-talk
- Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Vijay Kumar Banerjee via Core-talk
About RTEMS libbsdport networking drivers Vijay Kumar Banerjee via Core-talk
<2021>
2025
2026
<2021>
2025
2026
