2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository
From: Joel Sherrill via Core-talk <core-talk at aps.anl.gov>
To: junkes <junkes at fhi-berlin.mpg.de>
Cc: Core talk <core-talk at aps.anl.gov>, "rtems-devel at rtems.org" <devel at rtems.org>
Date: Thu, 4 Mar 2021 07:52:49 -0600
On Thu, Mar 4, 2021 at 6:39 AM junkes <junkes at fhi-berlin.mpg.de> wrote:
Hallo Vijay,
the next question ;-) I am trying to build EPICS.
with the external legacy stack there are some files missing:
rtems/rtems_bsdnet.h
librtemsNfs.h
rtems/telnetd.h
with RTEMS5 (with networking) one can find e.g. rtems_bsdnet.h here:
./kernel/cpukit/libnetworking/rtems/rtems_bsdnet.h
./rtems/5/powerpc-rtems5/beatnik/lib/include/rtems/rtems_bsdnet.h
Did you install the legacy package? If you installed it in the same place
as the RTEMS 5 BSP, I would expect it to be there. This SHOULD be
equivalent to prior split.
But I suppose this now means you could have the BSP, legacy stack
and libbsd installed in different places and setup include and library
paths to let the application build system decide which stack to us.
---joel
Heinz
On 2021-03-03 23:17, Vijay Kumar Banerjee wrote:
> Hi Heinz,
> Thanks for the hardware tests. It's great to see the tests running
> successfully on hardware!
> Best regards,
> Vijay
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Heinz Junkes via Core-talk
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository junkes via Core-talk
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Joel Sherrill via Core-talk
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Vijay Kumar Banerjee via Core-talk
Prev: Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository junkes via Core-talk
Next: Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Heinz Junkes via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
ANJ, 04 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
