2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: [Bug 1182091] Re: Make TIME field directly accessible
From: Jure Varlec via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 08 Mar 2021 20:21:14 -0000
Another possibility I see for adding direct access to the TIME field
while avoiding the drawback of keeping additional fields up to date is,
like in the first proposal, to handle it similar to SPC_DBADDR. But
instead of using a public field that would need to be updated after
every processing, use a private filed inside dbCommonPvt. This field
would only be updated when needed; as far as I can tell the appropriate
time is whenever SPC_SBADDR is handled. Specifically, dbEntryToAddr()
would, instead of calling the record's cvt_dbaddr(), convert
epicsTimeStamp to UINT64 and return a pointer to that as DBADDR.
Does this make sense? The way I see it, that's the only way to access
the value of the waveform, and thus should be sufficient as the only way
to access the converted value of the timestamp. Is my understanding
correct?
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1182091
Title:
Status in EPICS Base:
  Triaged
Bug description:
  Users often request the ability to access the TIME field directly.
  It could be provided as an array of 2 32-bit values, possibly with a specific string in ISO-8601 form say.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1182091/+subscriptions
Prev: [Bug 1905159] Re: Fix warnings from recent compiler versions Freddie Akeroyd via Core-talk
Next: [Bug 1905159] Re: Fix warnings from recent compiler versions mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: [Bug 1182091] Re: Make TIME field directly accessible Jure Varlec via Core-talk
Next: [Bug 1182091] Re: Make TIME field directly accessible Andrew Johnson via Core-talk
ANJ, 08 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
