2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: Re: ANN: RTEMS libnetworking relocation
From: Chris Johns via Core-talk <core-talk at aps.anl.gov>
To: Vijay Kumar Banerjee <vijay at rtems.org>, Michael Davidsaver <mdavidsaver at gmail.com>
Cc: Core talk <core-talk at aps.anl.gov>, Joel Sherrill <joel at rtems.org>
Date: Tue, 9 Mar 2021 09:49:48 +1100
I am sorry if I am a little late to this discussion.
On 4/3/21 9:07 am, Vijay Kumar Banerjee via Core-talk wrote:
> Hello Michael,
> On Wed, Mar 3, 2021 at 1:50 PM Michael Davidsaver <mdavidsaver at gmail.com> wrote:
>> On 3/1/21 2:43 PM, Vijay Kumar Banerjee via Core-talk wrote:
>>> Hello all,
>>> In RTEMS 6, there will be no cpukit/libnetworking in the RTEMS
>>> repository and it will be moved to its own separate repository. There
>>> are ongoing efforts in this direction and it is very close to
>>> completion. What's remaining, is to collect feedback from the users of
>>> the libnetworking stack.
>> How will this change be reflected through the rtems-source-builder script?
>> My current recipe for building with the legacy stack is eg.:
>>> ../source-builder/sb-set-builder --prefix=/opt/rtems/5 --log build.log \
>>>   --host=powerpc-rtems5 --target=powerpc-rtems5 \
>>>   --with-rtems-bsp=mvme3100 --with-rtems-legacy-network 5/rtems-kernel
> For this, my solution is that I have planned to work on the rtems
> source builder script and add a recipe for building the legacy stack.
> This means that if you have scripts that run the source-builder
> commands, they'll need to be updated to add another line for building
> the legacy stack. I can explore the possibility of triggering the
> legacy stack build recipe with an option like
> --whith-rtems-legacy-network. That might need no or fewer changes in
> your build scripts, but I'm not sure about how that'll turn out.
The stacks are considered separate packages and I hope they can be built
independently and installed side by side under the BSP. From an RTEMS
perspective if a stack (or any 3rd party package) can be built I would prefer
that happens so users can select which ever stack they want using options or
configurations they have control over.
>> Also, is this going the effect our current strategy of using the
>> RTEMS_HAS_NETWORKING macro?  Or, can you suggest another way to
>> programmatically identify which network stack is present?
> This is an interesting question and I don't have a very straight
> answer. The RTEMS_HAS_NETWORKING option will be removed along with the
> relocation patches and it will not be. A not-so-clean solution that I
> can think of is to add a check in the legacy-net stack waf, so that it
> builds only when there's no libbsd present. Doing this from the RTEMS
> won't be very clean as RTEMS needs to be built before any networking
> stack.
> Another solution that I can think of is to add a common config file in
> the build directory, which gets overwritten by whichever network stack
> is built. So if libbsd is built, it'll overwrite the file to indicate
> that libbsd stack is present. This can be clubbed together with a
> warning from waf.
> Thoughts/suggestions?
Can the EPICS build system check the BSP to see which libraries are present and
then decide which stack to use? The libbsd library is libbsd.a and I am not sure
what the net-legacy archive name is.
Chris
Re: ANN: RTEMS libnetworking relocation Vijay Kumar Banerjee via Core-talk
Re: ANN: RTEMS libnetworking relocation Johnson, Andrew N. via Core-talk
Re: ANN: RTEMS libnetworking relocation Michael Davidsaver via Core-talk
Prev: Build failed: EPICS Base 7 base-7.0-190 AppVeyor via Core-talk
Next: [Bug 1905159] Re: Fix warnings from recent compiler versions Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: Re: ANN: RTEMS libnetworking relocation Vijay Kumar Banerjee via Core-talk
Next: Re: ANN: RTEMS libnetworking relocation Vijay Kumar Banerjee via Core-talk
ANJ, 08 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
