2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: [Bug 1182091] Re: Make TIME field directly accessible
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Tue, 09 Mar 2021 09:30:25 -0000
There should be a way to add special processing for fields in dbCommon
that requires no updates to existing record supports. Then we could add
a "virtual" field to dbCommon that automagically converts the TIME data
to DBF_UINT64 on access. The mechanism to implement that is simple:
instead of calling the record support's special method directly, first
call the one for dbCommon; check via return value if that handled the
field, otherwise invoke the record support's special.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1182091
Title:
Status in EPICS Base:
  Triaged
Bug description:
  Users often request the ability to access the TIME field directly.
  It could be provided as an array of 2 32-bit values, possibly with a specific string in ISO-8601 form say.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1182091/+subscriptions
Prev: Build completed: EPICS Base 7 base-7.0-191 AppVeyor via Core-talk
Next: [Merge] ~bfrk/epics-base:scalar-get-optimization into epics-base:7.0 Ben Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: [Bug 1182091] Re: Make TIME field directly accessible Andrew Johnson via Core-talk
Next: [Bug 1182091] Re: Make TIME field directly accessible Jure Varlec via Core-talk
ANJ, 09 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
