2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: [Bug 1918614] Re: epicsLoadTest fails when INSTALL_LOCATION is set
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 11 Mar 2021 14:57:41 -0000
Ok, yes.  I didn't consider this case.
Since we don't have a portable recipe for defining macros with string
values as -D arguments, I guess I could re-use makeInstallDir.pl to
generate a header as with softIoc.
** Changed in: epics-base
       Status: New => Confirmed
   Importance: Undecided => Low
     Assignee: (unassigned) => mdavidsaver (mdavidsaver)
    Milestone: None => 7.0.5.1
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1918614
Title:
Status in EPICS Base:
  Confirmed
Bug description:
  When INSTALL_LOCATION is set, then
  modules/libcom/test/epicsLoadTest.cpp fails because it assumes that
  the EPICS libraries are always installed in ../../../../lib/.
  Bug introduced in commit 6f44f64a.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1918614/+subscriptions
[Bug 1918614] [NEW] epicsLoadTest fails when INSTALL_LOCATION is set Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: [Bug 1918614] [NEW] epicsLoadTest fails when INSTALL_LOCATION is set Dirk Zimoch via Core-talk
Next: [Bug 1918614] Re: epicsLoadTest fails when INSTALL_LOCATION is set mdavidsaver via Core-talk
ANJ, 11 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
