2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: [Bug 1918614] [NEW] epicsLoadTest fails when INSTALL_LOCATION is set
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 11 Mar 2021 09:36:19 -0000
Public bug reported:
When INSTALL_LOCATION is set, then modules/libcom/test/epicsLoadTest.cpp
fails because it assumes that the EPICS libraries are always installed
in ../../../../lib/.
Bug introduced in commit 6f44f64a.
** Affects: epics-base
     Importance: Undecided
         Status: New
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1918614
Title:
Status in EPICS Base:
  New
Bug description:
  modules/libcom/test/epicsLoadTest.cpp fails because it assumes that
  the EPICS libraries are always installed in ../../../../lib/.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1918614/+subscriptions
[Bug 1918614] Re: epicsLoadTest fails when INSTALL_LOCATION is set mdavidsaver via Core-talk
[Bug 1918614] Re: epicsLoadTest fails when INSTALL_LOCATION is set Dirk Zimoch via Core-talk
[Bug 1918614] Re: epicsLoadTest fails when INSTALL_LOCATION is set Andrew Johnson via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Ben Franksen via Core-talk
Next: Re: [epics-modules/lua] redirection in luash (#22) Ben Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: Build failed: epics-base base-alarm-msg-654 AppVeyor via Core-talk
Next: [Bug 1918614] Re: epicsLoadTest fails when INSTALL_LOCATION is set mdavidsaver via Core-talk
ANJ, 03 Jul 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
