** Changed in: epics-base
Status: Confirmed => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1918614
Title:
epicsLoadTest fails when INSTALL_LOCATION is set
Status in EPICS Base:
Fix Released
Bug description:
When INSTALL_LOCATION is set, then
modules/libcom/test/epicsLoadTest.cpp fails because it assumes that
the EPICS libraries are always installed in ../../../../lib/.
Bug introduced in commit 6f44f64a.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1918614/+subscriptions
- [Bug 1918614] [NEW] epicsLoadTest fails when INSTALL_LOCATION is set Dirk Zimoch via Core-talk
[Bug 1932033] Re: base EPICS compilation misses convertRelease.pl Andrew Johnson via Core-talk
[Bug 1587610] Re: Base does not build against RTEMS >=4.11 Andrew Johnson via Core-talk
<2021>
2025
2026
[Bug 1918614] Re: epicsLoadTest fails when INSTALL_LOCATION is set Dirk Zimoch via Core-talk
Re: [epics-modules/lua] redirection in luash (#22) Ben Franksen via Core-talk
<2021>
2025
2026
