2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: [Bug 1587610] Re: Base does not build against RTEMS >=4.11
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sun, 04 Jul 2021 03:44:51 -0000
** Changed in: epics-base
    Milestone: None => 7.0.6
       Status: Triaged => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1587610
Title:
Status in EPICS Base:
  Fix Released
Bug description:
  Currently no version of Base builds against RTEMS >=4.11.  Mainly due
  to use of internal/semi-public RTEMS APIs which are changed in 4.11.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1587610/+subscriptions
Prev: [Bug 1918614] Re: epicsLoadTest fails when INSTALL_LOCATION is set Andrew Johnson via Core-talk
Next: [Bug 1918909] Re: channel filters don't work wit PVA Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: [Bug 1722530] Re: Add userTag to epicsTimeStamp Andrew Johnson via Core-talk
Next: Build failed in Jenkins: EPICS-3.14 #1084 Jenkins EPICS PSI via Core-talk
ANJ, 04 Jul 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
