Public bug reported:
The recSup.h typed_rset get_enum_str() method has this prototype:
long (*get_enum_str)(const struct dbAddr *paddr, char *pbuffer);
The method gets no indication how large pbuffer is, so it's easy for it
to overflow it, although not by much.
The bi and bo records both hope it's one byte longer than their
associated ZNAM/ONAM fields (which are 26 bytes long) because they call
strncpy(pbuffer,,26) and then write a nil byte to pbuffer[26].
The mbbi and mbbo records at least don't overflow the buffer they assume
is 26 bytes long since they don't bother writing the nil byte after
calling strncpy(pbuffer,,26).
No other record types in Base define this method, which isn't trivial to
get called. I think this database should be doing it when lsi gets
processed, although valgrind doesn't seem to notice the overflow:
record(bi, bi) {
field(ZNAM, "26-character-enum-string.")
record(lsi, "lsi") {
field(SIZV, 16) # This is the minimum that lsi actually uses.
field(INP, "bi")
** Affects: epics-base
Importance: Medium
Status: Triaged
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1918762
Title:
rset::get_enum_str() API problem
Status in EPICS Base:
Triaged
Bug description:
it to overflow it, although not by much.
call strncpy(pbuffer,,26) and then write a nil byte to pbuffer[26].
assume is 26 bytes long since they don't bother writing the nil byte
after calling strncpy(pbuffer,,26).
to get called. I think this database should be doing it when lsi gets
record(bi, bi) {
field(INP, "bi")
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1918762/+subscriptions
[Bug 1905159] Re: Fix warnings from recent compiler versions Andrew Johnson via Core-talk
Build failed: epics-base base-integration-659 AppVeyor via Core-talk
<2021>
2025
2026
Build failed: epics-base base-integration-656 AppVeyor via Core-talk
<2021>
2025
2026
