** Changed in: epics-base
Assignee: (unassigned) => mdavidsaver (mdavidsaver)
Status: New => Confirmed
Importance: Undecided => Medium
Milestone: None => 7.0.5.1
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1918909
Title:
channel filters don't work wit PVA
Status in EPICS Base:
Confirmed
Bug description:
When using pvget with filters, only the number of elements is adjusted but not the data.
It works with Channel Access.
Example record:
record (aai, "TEST") {
field(FTVL, "SHORT")
field(NELM, "10")
field(INP, [9,8,7,6,5,4,3,2,1])
field(PINI, "YES")
info(test, "Hello World")
$ caget TEST TEST.{arr:{s:5}} TEST.{arr:{i:2}} 'TEST.{info:{n:"test"}}'
TEST 10 9 8 7 6 5 4 3 2 1 0
TEST.{arr:{s:5}} 5 4 3 2 1 0
TEST.{arr:{i:2}} 5 9 7 5 3 1
TEST.{info:{n:"test"}} Hello World
$ pvget TEST TEST.{arr:{s:5}} TEST.{arr:{i:2}} 'TEST.{info:{n:"test"}}'
TEST 2021-03-12 10:23:15.524 [9,8,7,6,5,4,3,2,1]
TEST.{arr:{s:5}} 2021-03-12 10:23:15.524 [9,8,7,6,5]
TEST.{arr:{i:2}} 2021-03-12 10:23:15.524 [9,8,7,6,5]
TEST.{info:{n:"test"}} 2021-03-12 10:23:15.524 9
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1918909/+subscriptions
- [Bug 1918909] [NEW] channel filters don't work wit PVA Dirk Zimoch via Core-talk
Re: Base 7.0.5 / pvDatabaseCPP 4.5.3 / pvDataCPP 8.0.4 (8.1.0?) Michael Davidsaver via Core-talk
Build failed: pva2pva 1.0.23 AppVeyor via Core-talk
<2021>
2025
2026
[Bug 1918909] Re: channel filters don't work wit PVA mdavidsaver via Core-talk
[Bug 1918909] Re: channel filters don't work wit PVA Andrew Johnson via Core-talk
<2021>
2025
2026
