2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:chfPluginImprovements into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+399636 at code.launchpad.net
Date: Mon, 15 Mar 2021 16:44:58 -0000
Now the short form works if there is only one parameter or only one parameter is mandatory (which means it is clear which parameter is meant).
Example: The "dec" filter:
Instead of: record.{dec:{n:5}} one can use record.{dec:5}
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/399636
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:chfPluginImprovements into epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:chfPluginImprovements into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: Base 7.0.5 / pvDatabaseCPP 4.5.3 / pvDataCPP 8.0.4 (8.1.0?) Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:chfPluginImprovements into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:chfPluginImprovements into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 18 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
