2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: Re: Base 7.0.5 / pvDatabaseCPP 4.5.3 / pvDataCPP 8.0.4 (8.1.0?)
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>
Cc: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Mon, 15 Mar 2021 17:20:03 +0000
I just committed this change for future releases, and similarly updated the published version on the EPICS site:
woz$ git tip -p
commit a514ab7b51db108336dc234cb774af2603e51696 (HEAD -> master, upstream/master, origin/master, origin/HEAD)
Author: Andrew Johnson <anj at anl.gov>
Date:   Mon Mar 15 12:12:15 2021 -0500
    Add missing removal instructions for destroy()
diff --git a/documentation/RELEASE_NOTES.md b/documentation/RELEASE_NOTES.md
index 6df2527..095b40c 100644
--- a/documentation/RELEASE_NOTES.md
+++ b/documentation/RELEASE_NOTES.md
@@ -5,6 +5,8 @@ This document summarizes the changes to the module between releases.
 ## Release 4.5.3 (EPICS 7.0.5 Feb 2021)
 * The previously deprecated destroy methods have been removed.
+  Any application code that was previously calling these can just remove
+  those calls.
 ## Release 4.5.2 (EPICS 7.0.3.2 May 2020)
- Andrew
On Mar 13, 2021, at 2:52 AM, Ralph Lange via Core-talk <core-talk at aps.anl.gov> wrote:
Thanks, Marty!
On Fri, 12 Mar 2021 at 22:18, Marty Kraimer via Core-talk <core-talk at aps.anl.gov> wrote:
On 3/12/21 8:06 AM, Ralph Lange via Core-talk wrote:
On Fri, 12 Mar 2021 at 12:29, Marty Kraimer via Core-talk <core-talk at aps.anl.gov> wrote:
On 3/12/21 3:41 AM, Ralph Lange via Core-talk wrote:
pvDatabaseCPP:
The destroy() methods have been deprecated in 2019 as part of a commit with the message "fix warning messages; at least on linux".
There seems to be no documentation - neither at the point of deprecation nor at the point of removal - how to migrate applications that are using this method.
I maintain that any application that uses destroy will have problems.
Any application that uses destroy should be fixed.
Yes, Marty, but: how?
If the code is calling the destroy method of base classes just remove the call.
That sentence should have been in the release notes.
Cheers,
~Ralph
Complexity comes for free, simplicity you have to work for.
Base 7.0.5 / pvDatabaseCPP 4.5.3 / pvDataCPP 8.0.4 (8.1.0?) Ralph Lange via Core-talk
Re: Base 7.0.5 / pvDatabaseCPP 4.5.3 / pvDataCPP 8.0.4 (8.1.0?) Ralph Lange via Core-talk
Re: Base 7.0.5 / pvDatabaseCPP 4.5.3 / pvDataCPP 8.0.4 (8.1.0?) Marty Kraimer via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:chfPluginImprovements into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Build completed: EPICS Base 7 base-7.0-249 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: Re: Base 7.0.5 / pvDatabaseCPP 4.5.3 / pvDataCPP 8.0.4 (8.1.0?) Ralph Lange via Core-talk
Next: Re: Base 7.0.5 / pvDatabaseCPP 4.5.3 / pvDataCPP 8.0.4 (8.1.0?) Michael Davidsaver via Core-talk
ANJ, 15 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
