2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Base 7.0.5 / pvDatabaseCPP 4.5.3 / pvDataCPP 8.0.4 (8.1.0?)
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Sat, 13 Mar 2021 09:52:13 +0100
Thanks, Marty!
On Fri, 12 Mar 2021 at 22:18, Marty Kraimer via Core-talk <core-talk at aps.anl.gov> wrote:
On 3/12/21 8:06 AM, Ralph Lange via Core-talk wrote:
On Fri, 12 Mar 2021 at 12:29, Marty Kraimer via Core-talk <core-talk at aps.anl.gov> wrote:
On 3/12/21 3:41 AM, Ralph Lange via Core-talk wrote:
pvDatabaseCPP:
The destroy() methods have been deprecated in 2019 as part of a commit with the message "fix warning messages; at least on linux".
There seems to be no documentation - neither at the point of deprecation nor at the point of removal - how to migrate applications that are using this method.
I maintain that any application that uses destroy will have problems.
Any application that uses destroy should be fixed.
Yes, Marty, but: how?
If the code is calling the destroy method of base classes just remove the call.
That sentence should have been in the release notes.
Cheers,
~Ralph
Re: Base 7.0.5 / pvDatabaseCPP 4.5.3 / pvDataCPP 8.0.4 (8.1.0?) Johnson, Andrew N. via Core-talk
Base 7.0.5 / pvDatabaseCPP 4.5.3 / pvDataCPP 8.0.4 (8.1.0?) Ralph Lange via Core-talk
Re: Base 7.0.5 / pvDatabaseCPP 4.5.3 / pvDataCPP 8.0.4 (8.1.0?) Ralph Lange via Core-talk
Re: Base 7.0.5 / pvDatabaseCPP 4.5.3 / pvDataCPP 8.0.4 (8.1.0?) Marty Kraimer via Core-talk
Prev: Build failed: EPICS Base 7 base-7.0-235 AppVeyor via Core-talk
Next: Re: IPv6 Ben Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Base 7.0.5 / pvDatabaseCPP 4.5.3 / pvDataCPP 8.0.4 (8.1.0?) Marty Kraimer via Core-talk
Next: Re: Base 7.0.5 / pvDatabaseCPP 4.5.3 / pvDataCPP 8.0.4 (8.1.0?) Johnson, Andrew N. via Core-talk
ANJ, 15 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
