2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:chfPluginImprovements into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+399636 at code.launchpad.net
Date: Fri, 19 Mar 2021 14:29:33 -0000
Another short form: If no argument at all is needed then just the filter name is sufficient (no :{} needed). Example: caget -a "record.{ts}"
I know this is not valid JSON5, but it is convenient and intuitive and works.
Can be stacked with other filters without problems: caget -a "record.{ts,arr:{i:3},dec:1}"
The filter is created as if called with {}.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/399636
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:chfPluginImprovements into epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:chfPluginImprovements into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Build failed: epics-base base-integration-667 AppVeyor via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:chfPluginImprovements into epics-base:7.0 Dirk Zimoch via Core-talk
Next: [Merge] ~dirk.zimoch/epics-base:chfPluginImprovements into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 19 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
