2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Merge] ~dirk.zimoch/epics-base:chfPluginImprovements into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+399636 at code.launchpad.net
Date: Fri, 19 Mar 2021 14:46:28 -0000
The proposal to merge ~dirk.zimoch/epics-base:chfPluginImprovements into epics-base:7.0 has been updated.
Description changed to:
1. Allow string arguments with arbitrarily long strings.
In addition to the chfPluginArgString argument type which works on fixed size char array members, chfPluginArgStringAlloc works on char* members. It performs the following actions:
* If a chfPluginArgStringAlloc is provided by the user, the char* member is first NULLed, then filled with a dynamically allocated string (which may fail due to memory shortage)
* If the same char* member may be provided multiple times (maybe under different names), the old value is freed before a new value is written.
* When the structure is released (before freePvt is called), the allocated strings are automatically freed and the char* member NULLed.
* If the parameter is optional and not provided my the user, the pointer is left untouched, allowing to initialize the char* member with a static string as a default value.
2. Allow short forms for filters with 1 or 0 parameters
* If only 1 parameter is required, {filter:value} can be used instead of {filter:{parameter:value}}
* If no parameter is requires, {filter} can be used instead of {filter:{}}
3. Documentarion changed: Use JSON5 features in examples.
For more details, see:
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/399636
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:chfPluginImprovements into epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:chfPluginImprovements into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Build failed: epics-base base-integration-668 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:chfPluginImprovements into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:chfPluginImprovements into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 09 Apr 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
