2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:chfPluginImprovements into epics-base:7.0
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: mp+399636 at code.launchpad.net
Date: Fri, 09 Apr 2021 13:25:56 -0000
I have added a check that the "extra-short form" is not followed by garbage. (And wrote tests for it.) It only accepts , or } now. It never crashed before but had accepted any separator like ; or # and did not check for closing }. That is fixed now.
The error message if } is missing is:
dbChannelCreate: parse error: premature EOF
If garbarge follows instead or a comma, the error is:
dbChannelCreate: lexical error: invalid char in json text.
These are exactly the same error one gets with the "long form" using :{}
Whitespace around the comma are possible just as usual.
I could not find a clever way to properly type check chfPluginArgString for char* vs char[] (without writing a new API in C++). Thus I will keep old chfPluginArgString and new chfPluginArgStringAlloc.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/399636
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:chfPluginImprovements into epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:chfPluginImprovements into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Build failed: epics-base base-dbChannel_get_count-unlocked-696 AppVeyor via Core-talk
Next: Build failed: epics-base base-integration-697 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: [Merge] ~dirk.zimoch/epics-base:chfPluginImprovements into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Build completed: EPICS Base 7 base-7.0-249 AppVeyor via Core-talk
ANJ, 09 Apr 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
