As you've found, this test does require a host to have at least one
"trusted" network interface to succeed. fyi. on my (Linux) laptop, I've
found it useful to keep a "dummy" software bridge w/o firewall
restrictions to allow PVA/CA to work locally with default settings. I
block that broadcast traffic out of the public interface.
$ cat /etc/network/interfaces
auto br0
iface br0 inet static
address 192.168.254.1
netmask 255.255.255.0
pre-up brctl addbr br0
post-down brctl delbr br0
** Changed in: epics-base
Status: New => Won't Fix
Assignee: (unassigned) => mdavidsaver (mdavidsaver)
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1918617
Title:
osiSockTest fails
Status in EPICS Base:
Won't Fix
Bug description:
osiSockTest reports one failure:
# udpSockFanoutTest()
# Interface 10.0.2.255:5064
# Not LO
# RX2 start
# RX1 start
# recvfrom error (11)
# RX1 end
# RX2 end
# Result: RX1 0:0 RX2 0:0
# Interface 192.168.122.255:5064
# Not LO
# RX1 start
# RX2 start
# RX2 end
# RX1 end
ok 19 - Found non-loopback interface
not ok 20 - Successes 0
The code is in line 403:
testOk(nsuccess>0, "Successes %u", nsuccess);
Here is my ifconfig:
enp0s3: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.0.2.15 netmask 255.255.255.0 broadcast 10.0.2.255
inet6 fe80::d9c8:1c30:9271:e21a prefixlen 64 scopeid 0x20<link>
ether 08:00:27:e4:35:68 txqueuelen 1000 (Ethernet)
RX packets 262876 bytes 333781671 (318.3 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 74111 bytes 6531238 (6.2 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 8721 bytes 875985 (855.4 KiB)
TX packets 8721 bytes 875985 (855.4 KiB)
virbr0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.122.1 netmask 255.255.255.0 broadcast 192.168.122.255
ether 52:54:00:8e:4b:63 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1918617/+subscriptions
- [Bug 1918617] [NEW] osiSockTest fails Dirk Zimoch via Core-talk
Build failed: EPICS Base 7 base-7.0-269 AppVeyor via Core-talk
scalar get optimization Ben Franksen via Core-talk
<2021>
2025
2026
[Bug 1918617] Re: osiSockTest fails Dirk Zimoch via Core-talk
Build failed: epics-base base-integration-656 AppVeyor via Core-talk
<2021>
2025
2026
