Dear Zirk,
After some tests I noticed that this change is causing a different
behavior on one of my modules. Reading the discussion and the commit
message I understood that this modification shouldn't change the base
behavior but I think in my case it is.
Is there some kind of configuration or test that I can do to force to
avoid the inheritance?
Thanks
Best Regards
Gabriel
On 3/3/21 9:28 AM, Dirk Zimoch via Core-talk wrote:
Compiles for all my targets.
Gabriel Fedel
Control System Engineer
Integrated Control System Division
The European Spallation Souce
Odarslövsvägen 113
224 84 Lund
- Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Johnson, Andrew N. via Core-talk
- Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Zimoch Dirk (PSI) via Core-talk
- Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Build completed: epics-base base-vfield-695 AppVeyor via Core-talk
Build failed in Jenkins: 3.15-pvDatabase-win64 #353 APS Jenkins via Core-talk
<2021>
2025
2026
<2021>
2025
2026
