2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Gabriel Fedel <gabriel.fedel at ess.eu>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Wed, 7 Apr 2021 16:24:07 +0000
Hi Gabriel,
On Apr 7, 2021, at 2:54 AM, Gabriel Fedel wrote:
> After some tests I noticed that this change is causing a different behavior on one of my modules. Reading the discussion and the commit message I understood that this modification shouldn't change the base behavior but I think in my case it is.
> Is there some kind of configuration or test that I can do to force to avoid the inheritance?
Can you give us a bit more detail about the change that you’re seeing and how you have narrowed it down to this modification to the Priority Inheritance change? What epicsThread objects are you using, what Linux are you running it on, are you getting a deadlock, etc.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Gabriel Fedel via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Build failed in Jenkins: epics-pvDatabase-win64 #898 APS Jenkins via Core-talk
Next: Build failed in Jenkins: 3.15-pvDatabase-win64 #354 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Gabriel Fedel via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Gabriel Fedel via Core-talk
ANJ, 08 Apr 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
