2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0
From: Gabriel Fedel via Core-talk <core-talk at aps.anl.gov>
To: "Johnson, Andrew N." <anj at anl.gov>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Thu, 8 Apr 2021 09:21:21 +0200
Hi Andrew,
On 4/7/21 6:24 PM, Johnson, Andrew N. wrote:
Hi Gabriel,
On Apr 7, 2021, at 2:54 AM, Gabriel Fedel wrote:
After some tests I noticed that this change is causing a different behavior on one of my modules. Reading the discussion and the commit message I understood that this modification shouldn't change the base behavior but I think in my case it is.
Is there some kind of configuration or test that I can do to force to avoid the inheritance?
Can you give us a bit more detail about the change that you’re seeing and how you have narrowed it down to this modification to the Priority Inheritance change? What epicsThread objects are you using, what Linux are you running it on, are you getting a deadlock, etc.
Sure! The issue I'm facing is a low level one and as far I could debug my IOC is kind of "loosing" one interruption from firmware. It is something a bit difficult to debug, but it looks to me that the threads could be having a different priority than before.
I could check that the issue is related to this change reverting the related commits and compiling all my modules with this patched version. Without these commits my IOC work as usual, with them I got the problem.
I've tested my IOC on 2 different Linux (CentOS 7 and a Yocto one used by ESS), both of them with the RT patch.
I'm not sure if I understood the question about the epicsThread, but the ones are created by one of my submodules have epicsThreadPriorityMedium.
- Andrew
Thank you
Gabriel Fedel
Control System Engineer
Integrated Control System Division
The European Spallation Souce
Odarslövsvägen 113
224 84 Lund
Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Gabriel Fedel via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Johnson, Andrew N. via Core-talk
Prev: Build failed: EPICS Base 7 base-7.0-297 AppVeyor via Core-talk
Next: Jenkins build is back to normal : epics-pvDatabase-win64 #899 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Johnson, Andrew N. via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Zimoch Dirk (PSI) via Core-talk
ANJ, 08 Apr 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
