Question: Example. Trying to set a location inside %AppData% by doing
creates an invalid path, because the backslashes disappear:
Shouldn't backslashes rather be treated verbatim here? The expansion is done by macLib before the epicsEnvSet command is being called. Do we need a modifier that allows verbatim macro replacement? The getenv() used by macLib converts '\' to '\\' when reading from the environment, but macLib seems to resolve (discard) the "escape sequence" further down in the process. Cheers, ~Ralph
| ANJ, 20 Apr 2021 |
Home
News
About
Talk
Base
Modules
Extensions
