2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: AW: Deadlock on VxWorks 6.7
From: "Zimoch Dirk \(PSI\) via Core-talk" <core-talk at aps.anl.gov>
To: "Zimoch Dirk (PSI)" <dirk.zimoch at psi.ch>, Michael Davidsaver <mdavidsaver at gmail.com>
Cc: "'core-talk at aps.anl.gov'" <core-talk at aps.anl.gov>
Date: Mon, 7 Jun 2021 12:53:40 +0000
Swapping taskLock() and intLock() had no effect.
Further investigation showed that the bug is somehow related to devIocStats (not loading it does not trigger the problem).
The problem seems to be caused by memory corruption. When printing spin->locked (which should be 0 or 1), I get 1919513701 = 0x7269746.
Maybe one out our modifications to devIocStats was buggy.
I'll keep you informed once I found the root cause of the problem...
> -----Ursprüngliche Nachricht-----
> Von: Core-talk <core-talk-bounces at aps.anl.gov> Im Auftrag von Zimoch Dirk
> (PSI) via Core-talk
> Gesendet: Mittwoch, 2. Juni 2021 16:35
> An: Michael Davidsaver <mdavidsaver at gmail.com>
> Cc: 'core-talk at aps.anl.gov' <core-talk at aps.anl.gov>
> Betreff: AW: Deadlock on VxWorks 6.7
> taskLock() does not disable interrupts intLock() does. epicsSpinLock() calls
> both.
> But the vxWorks manual suggest to call taskLock first and then intLock.
> epicsSpinLock calls intLock first and then taskLock.
> Not sure if this contributes to the problem. I will try the other way round....
> > Von: Zimoch Dirk (PSI)
> > Gesendet: Mittwoch, 2. Juni 2021 15:50
> > An: 'Michael Davidsaver' <mdavidsaver at gmail.com>
> > Checking taskLock for differences now....
> > > Von: Michael Davidsaver <mdavidsaver at gmail.com>
> > > Gesendet: Mittwoch, 2. Juni 2021 15:45
> > > An: Zimoch Dirk (PSI) <dirk.zimoch at psi.ch>
> > > Betreff: Re: Deadlock on VxWorks 6.7
> > > On 6/2/21 2:23 AM, Zimoch Dirk (PSI) via Core-talk wrote:
> > > > Hi,
> > > > When I use EPICS 7.0.5.1 or 7.0.4.1 on mv mv5100 running VxWorks
> 6.7, I
> > > see shortly after booting:
> > > > 0x132f380 (timerQueue): epicsSpinLock(0x1fda0b79): Deadlock.
> > > > Recursive lock, missed unlock or block when locked.Thread timerQueue
> > > (0x132f380) can't proceed, suspending.
> > > > Any idea?
> > > Not immediately, though I'm more familiar with the RTEMS side.
> > > I don't see any recursive call in the stack trace you provided.
> > > Is it possible that the behavior of taskLock() has changed wrt. disabling
> > > interrupts?
> > > > Why spinlocks on a single core CPU machine?
> > > The RTEMS and vxWorks implementations don't actually spin.
> > > https://github.com/epics-base/epics-
> base/blob/b777233efb06fa4e988c4f0738b0270dd3d095a3/modules/libcom/
> > > src/osi/os/vxWorks/osdSpin.c#L64-L86
Re: Deadlock on VxWorks 6.7 Ben Franksen via Core-talk
Deadlock on VxWorks 6.7 Zimoch Dirk (PSI) via Core-talk
Re: Deadlock on VxWorks 6.7 Michael Davidsaver via Core-talk
AW: Deadlock on VxWorks 6.7 Zimoch Dirk (PSI) via Core-talk
Prev: Re: EPICS Base 3.15.8: Name resolution requests directed to non-existing hosts block CA Server Goetz Pfeiffer via Core-talk
Next: Re: Tests on RTEMS-pc686-qemu Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: AW: Deadlock on VxWorks 6.7 Zimoch Dirk (PSI) via Core-talk
Next: Re: Deadlock on VxWorks 6.7 Ben Franksen via Core-talk
ANJ, 08 Jun 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
