taskLock() does not disable interrupts intLock() does. epicsSpinLock() calls both.
But the vxWorks manual suggest to call taskLock first and then intLock. epicsSpinLock calls intLock first and then taskLock.
Not sure if this contributes to the problem. I will try the other way round....
> -----Ursprüngliche Nachricht-----
> Von: Zimoch Dirk (PSI)
> Gesendet: Mittwoch, 2. Juni 2021 15:50
> An: 'Michael Davidsaver' <mdavidsaver at gmail.com>
> Cc: 'core-talk at aps.anl.gov' <core-talk at aps.anl.gov>
> Betreff: AW: Deadlock on VxWorks 6.7
> Checking taskLock for differences now....
> > Von: Michael Davidsaver <mdavidsaver at gmail.com>
> > Gesendet: Mittwoch, 2. Juni 2021 15:45
> > An: Zimoch Dirk (PSI) <dirk.zimoch at psi.ch>
> > Betreff: Re: Deadlock on VxWorks 6.7
> > On 6/2/21 2:23 AM, Zimoch Dirk (PSI) via Core-talk wrote:
> > > Hi,
> > > When I use EPICS 7.0.5.1 or 7.0.4.1 on mv mv5100 running VxWorks 6.7, I
> > see shortly after booting:
> > > 0x132f380 (timerQueue): epicsSpinLock(0x1fda0b79): Deadlock.
> > > Recursive lock, missed unlock or block when locked.Thread timerQueue
> > (0x132f380) can't proceed, suspending.
> > > Any idea?
> > Not immediately, though I'm more familiar with the RTEMS side.
> > I don't see any recursive call in the stack trace you provided.
> > Is it possible that the behavior of taskLock() has changed wrt. disabling
> > interrupts?
> > > Why spinlocks on a single core CPU machine?
> > The RTEMS and vxWorks implementations don't actually spin.
> > https://github.com/epics-base/epics-
> base/blob/b777233efb06fa4e988c4f0738b0270dd3d095a3/modules/libcom/
> > src/osi/os/vxWorks/osdSpin.c#L64-L86
- AW: Deadlock on VxWorks 6.7 Zimoch Dirk (PSI) via Core-talk
- Deadlock on VxWorks 6.7 Zimoch Dirk (PSI) via Core-talk
- Re: Deadlock on VxWorks 6.7 Michael Davidsaver via Core-talk
Heads-Up: Next Release of Base (C++) Ralph Lange via Core-talk
<2021>
2025
2026
<2021>
2025
2026
