2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: Re: softiIoc and softIocPVA incomplete on VxWorks (and others?)
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Dirk Zimoch <dirk.zimoch at psi.ch>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Thu, 10 Jun 2021 15:24:08 +0000
Hi Dirk,
I was expcting you to use --no-gc-sections to disable the garbage collection, but your error may mean it isn’t being turned anyway (although I can’t see how would it then be throwing out routines from the same object file as others it’s keeping – it used to be than a .o file was either included or not as a whole).
Glad you have a working solution in one place, I think that’s better than spraying changes throughout the tree.
- Andrew
On Jun 10, 2021, at 8:19 AM, Zimoch Dirk (PSI) <dirk.zimoch at psi.ch> wrote:
Hi Andrew,
I cannot use --gc-keep-exported  or --gc-sections:
unrecognized option '--gc-keep-exported'
--gc-sections and -r may not be used together
Adding 'MUNCH_LDFLAGS += -whole-archive' does not help because before softIoc.munch is made with the flag, softioc has already been made without it.
Adding 'OP_SYS_LDFLAGS += -whole-archive' works, but it applies to all *TestHarness.munch as well.
The size of softIoc grows only slightly but some TestHarnesses grow significantly.
softIoc.munch: 2.3 -> 2.5 MB
softIocPVA.munch: 8.8 -> 11 MB
caTestHarness.munch: 7.9 -> 9.1 MB
pvaTestHarness.munch: 6.4 -> 7.9 MB
pvDbTestHarness.munch: 6.5 -> 11 MB
pvdTestHarness.munch: 4.3 -> 5.1 MB
Comparing the two softIoc.nm files, I see the additional functions and classes, e.g. vxDev*, fdManager, epicsJob*, epicsMessageQueueReceiveWithTimeout, epicsMessageQueueSendWithTimeout, epicsTempFile, epicsThreadPool*, symFindByNameAndTypeEPICS, symFindByNameEPICS, yajl_gen_*
In particular the whole VME stuff was missing.
Pulling in unwanted full system libraries like libc is no issue for vxWorks. It does not implicitly link to any other libraries.
I finally resolved to adding this to my CONFIG_SITE.Common.vxWorksCommon:
OP_SYS_LDFLAGS += $(OP_SYS_LDFLAGS_$@)
OP_SYS_LDFLAGS_softIoc = -whole-archive
OP_SYS_LDFLAGS_softIocPVA = -whole-archive
Dirk
Von: Johnson, Andrew N. <anj at anl.gov>
Gesendet: Mittwoch, 9.
Juni 2021 18:46
An: Zimoch Dirk (PSI) <dirk.zimoch at psi.ch>
Betreff: Re: softiIoc and softIocPVA incomplete on VxWorks (and others?)
On Jun 9, 2021, at 11:03 AM, Zimoch Dirk (PSI) <dirk.zimoch at psi.ch> wrote:
It has always been a problem. I used to use iocCoreLibrary.munch instead of softIoc.munch for that reason (before I found out how to fix it). I will try your suggestions tomorrow.
Does APS (or anyone else) use softIoc.munch from base or your own ioc App? With an ioc App the new flag should not affect you.
I guess we only really use them for test purposes, so maybe that wouldn’t be an issue for us. However I would still prefer that these kinds of flag go into the target-specific files in configure/os rather than the Makefiles that build soft IOCs. I suspect having them in a central place might be helpful for you too, in case someone brings in or builds a special IOC binary since they wouldn’t have to know/remember to add the flag to their Makefile.
Unfortunately it doesn’t look like the VxWorks 6.9 version of ld supports the --gc-keep-exported flag that Michael suggested. It does have this, but it’s not obvious if/how it’s getting enabled:
`--gc-sections'
`--no-gc-sections'
     Enable garbage collection of unused input sections.  It is ignored
     on targets that do not support this option.  The default behaviour
     (of not performing this garbage collection) can be restored by
     specifying `--no-gc-sections' on the command line.
     `--gc-sections' decides which input sections are used by examining
     symbols and relocations.  The section containing the entry symbol
     and all sections containing symbols undefined on the command-line
     will be kept, as will sections containing symbols referenced by
     dynamic objects.  Note that when building shared libraries, the
     linker must assume that any visible symbol is referenced.  Once
     this initial set of sections has been determined, the linker
     recursively marks as used any section referenced by their
     relocations.  See `--entry' and `--undefined'.
     This option can be set when doing a partial link (enabled with
     option `-r').  In this case the root of symbols kept must be
     explicitely specified either by an `--entry' or `--undefined'
     option or by a `ENTRY' command in the linker script.
- Andrew
Gesendet: Mittwoch, 9. Juni 2021 17:51
Hi Dirk,
On Jun 9, 2021, at 3:35 AM, Zimoch Dirk (PSI) via Core-talk <core-talk at aps.anl.gov> wrote:
On VxWorks, softIoc.munch and softioc.PVA.munch are statically linked. As normal with static linkage, only those symbols actually used in the program are copied into the program. While this is usually totally sufficient, it becomes a problem when the statically linked program dynamically loads plugins as possible with 'dlload' (or 'ld' on VxWorks).
Those dynamically loaded plugins may use EPICS functions that are defined but not used in EPICS Base itself, resulting in load errors like this:
Warning: module 0x76a130 holds reference to undefined symbol epicsMessageQueueReceiveWithTimeout.
I have seen this on VxWorks only, as this is the only platform where I use static linkage with dynamic loading of modules. But I guess that other platforms may be affected as well. As I have never seen any complaints about this behavior, I may be the only one who uses softIoc this way.
Anyway, the problem is easy to fix, and I would appreciate to have the fix included future EPICS releases:
Add the linker flag -whole-archive when building softIoc/softIocPVA.
I have added PROD_LDFLAGS_vxWorks = --whole-archive to modules/database/src/std/softIoc/Makefile and modules/pva2pva/pdbApp/Makefile.
Maybe this or something similar (I don't know the corresponding Windows linker flag) should be done not only for VxWorks but for all statically built versions.
Is there a recent change that has caused this, or has it always been a problem?
Could you instead try adding the --whole-archive flag to either MUNCH_LDFLAGS or OP_SYS_LDFLAGS in your Base configure/os/CONFIG_SITE.Common.vxWorksCommon file. It’s only your site which needs that flag, and I don’t know what effect it will have on the memory needed by our VxWorks IOCs (APS does not use dynamic loading of plugins on any IOC architecture).
- Andrew
Complexity comes for free, simplicity you have to work for.
softiIoc and softIocPVA incomplete on VxWorks (and others?) Zimoch Dirk (PSI) via Core-talk
Re: softiIoc and softIocPVA incomplete on VxWorks (and others?) Johnson, Andrew N. via Core-talk
AW: softiIoc and softIocPVA incomplete on VxWorks (and others?) Zimoch Dirk (PSI) via Core-talk
Prev: AW: softiIoc and softIocPVA incomplete on VxWorks (and others?) Zimoch Dirk (PSI) via Core-talk
Next: Build failed in Jenkins: EPICS-3.14 #1060 Jenkins EPICS PSI via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Next: Re: softiIoc and softIocPVA incomplete on VxWorks (and others?) Michael Davidsaver via Core-talk
ANJ, 10 Jun 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
