2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: RE: Problem building ezcaIDL on Windows
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: EPICS core-talk <core-talk at aps.anl.gov>
Date: Fri, 11 Jun 2021 16:22:45 +0000
I have made some progress.  I changed the Makefile as follows:
diff --git a/Makefile b/Makefile
index cc33f71..4f85930 100644
--- a/Makefile
+++ b/Makefile
@@ -18,11 +18,13 @@ SCRIPTS_HOST = ezcaIDL.pro ezcaIDLWidgets.pro
SHARED_LIBRARIES=YES
LOADABLE_LIBRARY_HOST_Darwin = ezcaIDL
+STATIC_BUILD=YES
LIBRARY_HOST_DEFAULT = ezcaIDL
LIBRARY_HOST_Darwin = -nil-
ezcaIDL_LDFLAGS_WIN32 += /manifest
ezcaIDL_SRCS = ezcaIDL.c
ezcaIDL_LIBS += ezca EzcaScan ca Com
-ezcaIDL_SYS_LIBS_WIN32 = ws2_32 advapi32 user32
+ezcaIDL_SYS_LIBS_WIN32 = ws2_32 advapi32 user32 msvcrt
+USR_LDFLAGS_WIN32 += /nodefaultlib:libcmt
STATIC_BUILD=YES was required to get the linker to use the statically built libraries for ezca and EzcaScan.
I needed to add msvcrt to SYS_LIBS_WIN32, otherwise it gave an error that functions from the C run-time were undefined.
I needed to add the nodefaultlib to prevent a warning the libcmt was not compatible.
Perhaps there is a better solution to the above 2 problems.
Once I made those changes then I still get warnings like this:
ezcaIDL.obj : warning LNK4197: export 'EzcaMonitorQueue_Zero' specified multiple times; using first specification
but it builds OK.  It is exporting the undecorated symbols, as I want.  The DLL does not depend on ezca.dll or EzcaScan.dll, as I want.  However, it does depend on Com.dll and ca.dll, which I do not want.
I then tried a different approach.  I used the windows-x64-static architecture, rather than windows-x64.  I was able to revert to the original Makefile.  Although it is the static architecture, the Makefile defines SHARED_LIBRARIES=YES so it will build the DLL. I still get the warnings about exports defined multiple times.  I then get this error:
link -nologo -subsystem:windows -dll  -incremental:no -opt:ref -release  -MACHINE:X64    /manifest  -out:ezcaIDL.dll -implib:ezcaIDL.lib -def:../ezcaIDL.def   ezcaIDL.obj      ../../../lib/windows-x64-static/ezca.lib  ../../../lib/windows-x64-static/EzcaScan.lib  ../../../../base/lib/windows-x64-static/ca.lib  ../../../../base/lib/windows-x64-static/Com.lib  ws2_32.lib advapi32.lib user32.lib
   Creating library ezcaIDL.lib and object ezcaIDL.exp
Com.lib(osdFindAddr.obj) : error LNK2019: unresolved external symbol __imp_SymSetOptions referenced in function epicsFindAddr
Com.lib(osdFindAddr.obj) : error LNK2019: unresolved external symbol __imp_SymGetLineFromAddr64 referenced in function epicsFindAddr
Com.lib(osdFindAddr.obj) : error LNK2019: unresolved external symbol __imp_SymInitialize referenced in function epicsFindAddr
Com.lib(osdFindAddr.obj) : error LNK2019: unresolved external symbol __imp_SymFromAddr referenced in function epicsFindAddr
ezcaIDL.dll : fatal error LNK1120: 4 unresolved externals
make[1]: *** [../../../../base/configure/RULES_BUILD:298: ezcaIDL.dll] Error 1120
make[1]: Leaving directory 'H:/epics/extensions_new/src/ezcaIDL/O.windows-x64-static'
make: *** [../../../base/configure/RULES_ARCHS:58: install.windows-x64-static] Error 2
Is there a way around that error?
Sent: Friday, June 11, 2021 9:50 AM
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Note that the existing version of the DLL am using was built in 2013, so it is definitely built with old versions of base and Visual Studio.
This is the output of dumpbin/exports, which shows that the DLL is exporting undecorated symbols, which is what I need.
H:\epics\extensions\bin\windows-x64>dumpbin /exports ezcaIDL.dll
Microsoft (R) COFF/PE Dumper Version 14.00.24215.1
Copyright (C) Microsoft Corporation.  All rights reserved.
Dump of file ezcaIDL.dll
File Type: DLL
  Section contains the following exports for ezcaIDL.dll
    00000000 characteristics
    5151CC01 time date stamp Tue Mar 26 11:25:37 2013
        0.00 version
           1 ordinal base
          53 number of functions
          53 number of names
    ordinal hint RVA      name
          1    0 00060A80 EzcaAddMonitorArray
          2    1 00060790 EzcaCheckMonitorArray
          3    2 00060910 EzcaClearMonitorArray
          4    3 0005FFC0 EzcaDebug
          5    4 00060DA0 EzcaGetArrayEventValues
          6    5 00060E20 EzcaGetArrayTypeCount
          7    6 00060EE0 EzcaGetArrayValues
          8    7 00060FB0 EzcaGetError
          9    8 00060850 EzcaGetMonitorArray
         10    9 00060290 EzcaInit
         11    A 000600F0 EzcaMonitorQueue_Add
         12    B 00060090 EzcaMonitorQueue_Clear
         13    C 00060160 EzcaMonitorQueue_Get
         14    D 00060030 EzcaMonitorQueue_Zero
         15    E 00061160 EzcaMonitorScan_Add
         16    F 00060BA0 EzcaMonitorScan_Clear
         17   10 00060B70 EzcaMonitorScan_Get
         18   11 00060B10 EzcaMonitorScan_Zero
         19   12 00060260 EzcaPendEvent
         20   13 00060C00 EzcaPutArrayEventValues
         21   14 00060CD0 EzcaPutArrayValues
         22   15 00060190 EzcaSearchList
        23   16 0005FFA0 EzcaSetPendTime
         24   17 000610C0 EzcaTimeStamp
         25   18 00060000 EzcaVersion
         26   19 000602C0 ezcaIDLAutoErrorMessageOff
         27   1A 000602E0 ezcaIDLAutoErrorMessageOn
         28   1B 000610E0 ezcaIDLClearMonitor
         29   1C 00060340 ezcaIDLDebugOff
         30   1D 00060360 ezcaIDLDebugOn
         31   1E 00060380 ezcaIDLEndGroup
         32   1F 000604B0 ezcaIDLEndGroupWithReport
         33   20 00060760 ezcaIDLGet
         34   21 00061140 ezcaIDLGetControlLimits
         35   22 000605C0 ezcaIDLGetCountAndType
         36   23 000603A0 ezcaIDLGetEnumStrings
         37   24 00060680 ezcaIDLGetErrorString
         38   25 00061120 ezcaIDLGetGraphicLimits
         39   26 00060740 ezcaIDLGetPrecision
         40   27 00060530 ezcaIDLGetRetryCount
         41   28 00060720 ezcaIDLGetStatus
         42   29 00060550 ezcaIDLGetTimeout
         43   2A 00060700 ezcaIDLGetUnits
         44   2B 000605A0 ezcaIDLNewMonitorValue
         45   2C 000606E0 ezcaIDLPerror
         46   2D 00060650 ezcaIDLPut
         47   2E 00060620 ezcaIDLPutOldCa
         48   2F 00061100 ezcaIDLSetMonitor
         49   30 00060570 ezcaIDLSetRetryCount
         50   31 00060580 ezcaIDLSetTimeout
         51   32 00060390 ezcaIDLStartGroup
         52   33 00060300 ezcaIDLTraceOff
         53   34 00060320 ezcaIDLTraceOn
  Summary
       17000 .data
        8000 .pdata
       22000 .rdata
        2000 .reloc
        1000 .rsrc
       6E000 .text
This is the output of dumpbin /imports, which shows that although the DLL uses the Com and ca libraries, they are statically linked into the DLL, there is no dependency of the DLL on Com.dll or ca.dll.  That is what I want, so I can easily distribute the DLL without any dependencies.
H:\epics\extensions\bin\windows-x64>dumpbin /imports ezcaIDL.dll
File Type: DLL
  Section contains the following imports:
    WS2_32.dll
             18006F390 Import Address Table
             18008FFA0 Import Name Table
                     0 time date stamp
                     0 Index of first forwarder reference
                          36 WSAIoctl
                             Ordinal   115
                             Ordinal   116
                             Ordinal    23
                             Ordinal     3
                             Ordinal    51
                             Ordinal    52
                             Ordinal    14
                             Ordinal    57
                             Ordinal     4
                             Ordinal   111
                             Ordinal    22
                             Ordinal    21
                             Ordinal    16
                             Ordinal    19
                             Ordinal     7
                             Ordinal    15
                             Ordinal    10
                             Ordinal    17
                             Ordinal     8
                             Ordinal     9
                             Ordinal     6
                             Ordinal    20
                             Ordinal     2
    ADVAPI32.dll
             18006F000 Import Address Table
             18008FC10 Import Name Table
                     0 time date stamp
                         15E GetUserNameA
    USER32.dll
             18006F380 Import Address Table
             18008FF90 Import Name Table
                     0 time date stamp
                         1FC MessageBoxA
    KERNEL32.dll
             18006F010 Import Address Table
             18008FC20 Import Name Table
                     0 time date stamp
                          79 CreateFileA
                         3D5 SetEnvironmentVariableA
                          55 CompareStringW
                          52 CompareStringA
                         400 SetStdHandle
                         19A GetConsoleOutputCP
                         486 WriteConsoleA
                         240 GetStringTypeW
                         362 ReadFile
                         3E4 SetFilePointer
                         1E8 GetLocaleInfoA
                         2A4 HeapReAlloc
                         2DD LCMapStringW
                         314 MultiByteToWideChar
                         2DB LCMapStringA
                         142 FlushFileBuffers
                         196 GetConsoleMode
                         184 GetConsoleCP
                         2A6 HeapSize
                         23D GetStringTypeA
                         1F9 GetModuleHandleW
                         354 RaiseException
                         2D5 IsValidCodePage
                         468 WaitForSingleObject
                         3D8 SetEvent
                          73 CreateEventA
                          43 CloseHandle
                         438 TlsGetValue
                         1AA GetCurrentProcess
                         1AD GetCurrentThread
                         2B4 InitializeCriticalSection
                         439 TlsSetValue
                         215 GetPriorityClass
                         425 Sleep
                         24E GetSystemTimeAdjustment
                         2E9 LeaveCriticalSection
                         40F SetThreadPriority
                          DA EnterCriticalSection
                         1C7 GetExitCodeThread
                         261 GetThreadPriority
                          BF DeleteCriticalSection
                         1AE GetCurrentThreadId
                          D5 DuplicateHandle
                         436 TlsAlloc
                         437 TlsFree
                         42B SuspendThread
                         387 ResumeThread
                         148 FormatMessageA
                          95 CreateProcessA
                         239 GetStartupInfoA
                         1E6 GetLastError
                         2F7 LocalFree
                          8C CreateMutexA
                         371 ReleaseMutex
                         275 GetVersionExA
                         42F SystemTimeToTzSpecificLocalTime
                         42E SystemTimeToFileTime
                          51 CompareFileTime
                         34E QueryPerformanceCounter
                         24F GetSystemTimeAsFileTime
                         111 FileTimeToSystemTime
                         26B GetTimeZoneInformation
                         34F QueryPerformanceFrequency
                         140 FlsSetValue
                         170 GetCommandLineA
                         2A1 HeapFree
                         29D HeapAlloc
                         220 GetProcAddress
                         105 ExitProcess
                         442 UnhandledExceptionFilter
                         419 SetUnhandledExceptionFilter
                         389 RtlCaptureContext
                         490 WriteConsoleW
                         1D8 GetFileType
                         23B GetStdHandle
                         106 ExitThread
                          A3 CreateThread
                         1AF GetDateFormatA
                         268 GetTimeFormatA
                         392 RtlPcToFileHeader
                         431 TerminateProcess
                         2CB IsDebuggerPresent
                         397 RtlVirtualUnwind
                         390 RtlLookupFunctionEntry
                         396 RtlUnwindEx
                          D6 EncodePointer
                          B8 DecodePointer
                         13F FlsGetValue
                         13E FlsFree
                         3F0 SetLastError
                         13D FlsAlloc
                         3EC SetHandleCount
                         1F4 GetModuleFileNameA
                         14B FreeEnvironmentStringsA
                         1C0 GetEnvironmentStrings
                         14C FreeEnvironmentStringsW
                         47E WideCharToMultiByte
                         1C2 GetEnvironmentStringsW
                         2A5 HeapSetInformation
                         29F HeapCreate
                         2A0 HeapDestroy
                         266 GetTickCount
                         1AB GetCurrentProcessId
                         491 WriteFile
                         2EB LoadLibraryA
                         2B5 InitializeCriticalSectionAndSpinCount
                         15C GetCPInfo
                         153 GetACP
                         213 GetOEMCP
  Summary
       17000 .data
        8000 .pdata
       22000 .rdata
        2000 .reloc
        1000 .rsrc
       6E000 .text
From: Core-talk <core-talk-bounces at aps.anl.gov> On Behalf Of Mark Rivers via Core-talk
Sent: Friday, June 11, 2021 9:37 AM
Subject: Problem building ezcaIDL on Windows
I am trying to build the master branch of https://github.com/epics-extensions/ezcaIDL on windows-x64 with base 7.0.4 and VS 2015.  This used to build OK, either on an earlier version of base or VS or both.
This extension builds a shareable library/DLL to call Channel Access from IDL.  It depends on extensions/ezca and extensions/EzcaScan.  Both of those libraries build fine on Windows.
ezcaIDL builds fine on Linux.  However, on Windows I get this:
H:\epics\extensions\src\ezcaIDL>make
make -C O.windows-x64 -f ../Makefile TOP=../../.. \
    T_A=windows-x64 install
make[1]: Entering directory 'H:/epics/extensions/src/ezcaIDL/O.windows-x64'
link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref -release  -MACHINE:X64    /manifest  -out:ezcaIDL.dll -implib:ezcaIDL.lib -def:../ezcaIDL.def   ezcaIDL.obj      ../../../lib/windows-x64/ezca.lib  ../../../lib/windows-x64/EzcaScan.lib  ../../../../base/lib/windows-x64/ca.lib  ../../../../base/lib/windows-x64/Com.lib  ws2_32.lib advapi32.lib user32.lib
ezcaIDL.obj : warning LNK4197: export 'EzcaMonitorQueue_Clear' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaMonitorQueue_Add' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaMonitorQueue_Get' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaCheckMonitorArray' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaGetMonitorArray' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaClearMonitorArray' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaAddMonitorArray' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaMonitorScan_Zero' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaMonitorScan_Get' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaMonitorScan_Clear' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaMonitorScan_Add' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaPutArrayEventValues' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaPutArrayValues' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaGetArrayEventValues' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaGetArrayTypeCount' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaGetArrayValues' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaGetError' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaSearchList' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaTimeStamp' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaSetPendTime' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaPendEvent' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaInit' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaDebug' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'EzcaVersion' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLAutoErrorMessageOff' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLAutoErrorMessageOn' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLTraceOff' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLTraceOn' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLDebugOff' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLDebugOn' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLEndGroup' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLStartGroup' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLGetEnumStrings' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLEndGroupWithReport' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLGetRetryCount' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLGetTimeout' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLSetRetryCount' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLSetTimeout' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLNewMonitorValue' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLClearMonitor' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLSetMonitor' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLGetCountAndType' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLPutOldCa' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLPut' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLGetErrorString' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLPerror' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLGetUnits' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLGetStatus' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLGetPrecision' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLGetGraphicLimits' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLGetControlLimits' specified multiple times; using first specification
ezcaIDL.obj : warning LNK4197: export 'ezcaIDLGet' specified multiple times; using first specification
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_search_list
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_getArrayEvent
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaTraceOn
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaGetTimeout
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaTraceOff
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_getTypeCount
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaNewMonitorValue
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaSetRetryCount
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaSetMonitor
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaDebugOff
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaEndGroup
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaEndGroupWithReport
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_version
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaGetPrecision
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_scanClearMonitor
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_scanZeroMonitor
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_monitorArrayCheck
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaPut
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_debug
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaPutOldCa
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaGetRetryCount
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaPvToChid
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaDebugOn
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_get_error_array
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaGetGraphicLimits
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaGetStatus
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaGetControlLimits
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_queueClear
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaAutoErrorMessageOn
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_queueGet
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_scanGetMonitor
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_putArray
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaGetErrorString
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_scanAdd
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_setPendTime
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaSetTimeout
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaFree
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_CA
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaClearMonitor
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaAutoErrorMessageOff
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_timeStamp
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_monitorArrayGet
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_monitorArrayAdd
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_queueAdd
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaStartGroup
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_monitorArrayClear
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_queueZero
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_putArrayEvent
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaGetUnits
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_Ezca_init
ezcaIDL.obj : error LNK2001: unresolved external symbol __imp_ezcaPerror
ezcaIDL.dll : fatal error LNK1120: 53 unresolved externals
make[1]: Leaving directory 'H:/epics/extensions/src/ezcaIDL/O.windows-x64'
make: *** [../../../base/configure/RULES_ARCHS:58: install.windows-x64] Error 2
Note that it uses a .DEF file to define what symbols should be exported.
Has support for that changed?  If so, how do I need to do it now?
Re: Problem building ezcaIDL on Windows Michael Davidsaver via Core-talk
Problem building ezcaIDL on Windows Mark Rivers via Core-talk
RE: Problem building ezcaIDL on Windows Mark Rivers via Core-talk
Prev: RE: Problem building ezcaIDL on Windows Mark Rivers via Core-talk
Next: Re: Problem building ezcaIDL on Windows Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
ANJ, 11 Jun 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
