2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: rtems IMFS support/compatibility
From: "Siddons, David via Core-talk" <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>, EPICS core-talk <core-talk at aps.anl.gov>
Date: Sun, 13 Jun 2021 23:02:35 +0000
Hi Michael,
   At the same time Eric was working with the uC5282, I was working on the uC5272, a very similar board. Eric sent me the attached shell script to build the composite image, and I used it successfully for my project. The uC5282 / uC5272 had a very simple bootloader which basically loaded the code and jumped to a start.
Pete.
From: Michael Davidsaver <mdavidsaver at gmail.com>
Sent: Sunday, June 13, 2021 2:58 PM
To: EPICS core-talk <core-talk at aps.anl.gov>
Cc: Siddons, David <siddons at bnl.gov>
Subject: rtems IMFS support/compatibility
Possible usage of IMFS came up in a recent tech-talk thread[1].  I tried again to make
use of the logic in initialize_local_filesystem() from rtems_init.c, and this time was
successful.  Although with some caveats.
As far as I can tell, only the uC5282 target provides special symbols _DownloadLocation,
_FlashBase, and _FlashSize.  I found a archived mail from Eric Norum [2] which gives a
hint about how he meant this to be used
> I do this for my standalone EPICS applications by concatenating the tar file at the end of the bootstrap flash. ...
I couldn't figure out how to make use of this logic as is with pc386 (QEMU).  By changing
the pointer gymnastics to something simpler I was able to load a tar containing an st.cmd
and a .dbd file.  (see attached)
I don't think the idea of concatenating an FS image to an ELF executable or .boot file
can be generalized though.
Linking a tar into an executable can be generalized, but means an executable for each
IOC instance, which seems kind of awkward.
The use of rtems_tarfs_load() also carries a couple of surprises.
1. The 'tar_size' argument is actually not a size, but an upper bound address.
2. Missing directories are not created automatically, and files in them are silently ignored.
eg. "tar -cf image.tar dbd/foo.dbd st.cmd" results in a tar with only two REGTYPE
entries, and no DIRTYPE entry.  "tar -xf" will automatically create "dbd/", but
rtems_tarfs_load() does not.  Further, "foo.dbd" is then ignored without error.
It took me awhile to figure out what was going on...
This can be worked around by "tar -cf image.tar dbd st.cmd", or more explicitly
"tar --no-recursion -cf image.tar dbd dbd/foo.dbd st.cmd", to include an DIRTYPE
entry for "dbd".  (without necessarily including all of its contents.)
[1] https://epics.anl.gov/tech-talk/2021/msg01192.php
[2] https://urldefense.com/v3/__https://lists.rtems.org/pipermail/users/2010-March/055394.html__;!!P4SdNyxKAPE!U6VAZxrAeNU1ltIFOQ4OVGtETAw5w-CLeKbpFrwWxmOwDLoUlylnQyJqrpasmP8$
Attachment: make-tarball.sh
Description: make-tarball.sh
rtems IMFS support/compatibility Michael Davidsaver via Core-talk
Prev: rtems IMFS support/compatibility Michael Davidsaver via Core-talk
Next: Re: rtems IMFS support/compatibility Gedare Bloom via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
ANJ, 15 Jun 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
