Testing INSTALL_LOCATION with the current 7.0 branch HEAD appears to
succeed, though I do see the message you mention. So I guess this is a
nuisance message.
$ git clone --depth 1 https://github.com/epics-base/epics-base.git
$ make -C epics-base INSTALL_LOCATION=$PWD/inst -sj8
Can't open perl script ".": Is a directory
Can't open perl script "..": Is a directory
Can't open perl script "../..": Is a directory
Can't open perl script "../../..": Is a directory
$ ls inst/bin/linux-x86_64/
acctst caput dbdToRecordtypeH.pl iocLogServer munch.pl
** Changed in: epics-base
Status: New => Triaged
Importance: Undecided => Low
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1932033
Title:
base EPICS compilation misses convertRelease.pl
Status in EPICS Base:
Triaged
Bug description:
Seems the convertRelease.pl is to be used by installation scripts, but
it is not found.
The problem occurs when the installation directory is different from the source directory
(I tried it by adding a file configure/CONFIG_SITE.local containing INSTALL_LOCATION=path)
and the only mark seen are messages on standard error like: Can't open perl script ".."
The reason for the message is that the EPICS installation scripts cannot find some script
needed and likely its job is not done, resulting in invalid EPICS installation (it doesn't
stop the installation and can be easily overlooked, unless the standard error is logged).
The message dosn't tell the script name - seems a variable which is to specify the name
contains an empty string when it is used and a file of empty name is looked for in the
parent directory, therefore the name ".." (and later "../..") is in the message.
I found 2 workarounds for the problem:
1. Before 'make' copy "src/tools" from source to installation directory (the copy has to be
in "<installation-dir>/src/tools") - the installation looks for the "convertRelease.pl"
there instead in the "<source-dir>/src/tools".
2. In the configure/CONFIG_SITE.local add a line "CONVERTRELEASE=<convertRelease.pl-path>";
I found it also needed setting execute permission for the "convertRelease.pl".
Unfortunately, I don't know the Perl language and I am unable to make a real fix.
All this was tried on Linux Ubuntu 18.04 having installed GNU Make 4.1,
binutils, Perl v5.26.1, perl-modules, GCC/G++ 7.3.0, libreadline-dev.
Also, I tried it on NI Linux Real-Time 6.0 with the same problem
(I didn't try the workarounds on the NI Linux yet).
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1932033/+subscriptions
- [Bug 1932033] [NEW] base EPICS compilation misses convertRelease.pl Jerzy Tarasiuk via Core-talk
[Bug 1932033] Re: base EPICS compilation misses convertRelease.pl Jerzy Tarasiuk via Core-talk
CA incompatibilities? Zimoch Dirk (PSI) via Core-talk
<2021>
2025
2026
<2021>
2025
2026
