See <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/354/display/redirect?page=changes>
Changes:
[anj] makeBaseApp.pl: Allow relative paths to $0
[anj] GHA: Don't worry if no artifacts to upload
[mdavidsaver] quiet use "may be used uninitialized" warnings
Started by an SCM change
Building in workspace <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/>
[WS-CLEANUP] Deleting project workspace...
[WS-CLEANUP] Deferred wipeout is used...
[WS-CLEANUP] Done
Cloning the remote Git repository
Cloning repository https://git.launchpad.net/epics-base
> git init <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/> # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
> git --version # timeout=10
> git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*
> git config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
> git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
> git rev-parse origin/7.0^{commit} # timeout=10
Checking out Revision 256babf9614a199709e2728f0ecd79bf57b668ec (origin/7.0)
> git config core.sparsecheckout # timeout=10
> git checkout -f 256babf9614a199709e2728f0ecd79bf57b668ec
Commit message: "quiet use "may be used uninitialized" warnings"
> git rev-list --no-walk 3c329c1b48fd25f337745764dd853c3d343f12b5 # timeout=10
> git remote # timeout=10
> git submodule init # timeout=10
> git submodule sync # timeout=10
> git config --get remote.origin.url # timeout=10
> git config -f .gitmodules --get-regexp ^submodule\.(.+)\.url # timeout=10
> git config --get submodule.modules/pvData.url # timeout=10
> git config -f .gitmodules --get submodule.modules/pvData.path # timeout=10
> git submodule update --init --recursive --remote modules/pvData
> git config --get submodule.modules/pvAccess.url # timeout=10
> git config -f .gitmodules --get submodule.modules/pvAccess.path # timeout=10
> git submodule update --init --recursive --remote modules/pvAccess
> git config --get submodule.modules/normativeTypes.url # timeout=10
> git config -f .gitmodules --get submodule.modules/normativeTypes.path # timeout=10
> git submodule update --init --recursive --remote modules/normativeTypes
> git config --get submodule.modules/pvaClient.url # timeout=10
> git config -f .gitmodules --get submodule.modules/pvaClient.path # timeout=10
> git submodule update --init --recursive --remote modules/pvaClient
> git config --get submodule.modules/pvDatabase.url # timeout=10
> git config -f .gitmodules --get submodule.modules/pvDatabase.path # timeout=10
> git submodule update --init --recursive --remote modules/pvDatabase
> git config --get submodule.modules/pva2pva.url # timeout=10
> git config -f .gitmodules --get submodule.modules/pva2pva.path # timeout=10
> git submodule update --init --recursive --remote modules/pva2pva
> git config --get submodule..ci.url # timeout=10
> git config -f .gitmodules --get submodule..ci.path # timeout=10
> git submodule update --init --recursive --remote .ci
[EPICS-7] $ /bin/sh -xe /tmp/jenkins2170091327198413167.sh
+ tar xfz /net/sls-hafs/export/exchange/home/zimoch/epics/PSIconfig.tgz
+ patch -p1
patching file configure/os/CONFIG_SITE.Common.vxWorksCommon
patching file configure/os/CONFIG_SITE.linux-x86.Common
Hunk #1 FAILED at 7.
1 out of 1 hunk FAILED -- saving rejects to file configure/os/CONFIG_SITE.linux-x86.Common.rej
patching file configure/os/CONFIG_SITE.linux-x86_64.Common
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
- Build failed in Jenkins: EPICS-7 #355 Jenkins EPICS PSI via Core-talk
- Build failed in Jenkins: EPICS-7 #353 Jenkins EPICS PSI via Core-talk
Re: CA incompatibilities? Mark Rivers via Core-talk
[Bug 1932033] Re: base EPICS compilation misses convertRelease.pl Andrew Johnson via Core-talk
<2021>
2025
2026
<2021>
2025
2026
