2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: [Bug 1932033] Re: base EPICS compilation misses convertRelease.pl
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Tue, 15 Jun 2021 20:18:27 -0000
Hi Jerzy, this is rather more complicated than you realize because the
EPICS build system has to be able to find and run the convertRelease.pl
script from many different places (including the PVA submodules) in
various different build configurations and states.
I believe the fix should actually be this, if you get a chance please
apply the patch and try it:
diff --git a/configure/CONFIG_BASE b/configure/CONFIG_BASE
--- a/configure/CONFIG_BASE
+++ b/configure/CONFIG_BASE
@@ -34,7 +34,8 @@ endif # BASE_TOP
 #   FIND_TOOL is for scripts run before the build reaches src/tools.
 TOOLS = $(abspath $(EPICS_BASE_HOST_BIN))
-FIND_TOOL = $(firstword $(wildcard $(TOOLS)/$(1) $(EPICS_BASE)/src/tools/$(1)))
+FIND_TOOL = $(firstword $(wildcard $(TOOLS)/$(1) \
+    $(TOP)/src/tools/$(1)) $(EPICS_BASE)/src/tools/$(1))
 # EPICS Base build tools and tool flags
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1932033
Title:
Status in EPICS Base:
  Triaged
Bug description:
  Seems the convertRelease.pl is to be used by installation scripts, but
  it is not found.
  The problem occurs when the installation directory is different from the source directory
  (I tried it by adding a file configure/CONFIG_SITE.local containing INSTALL_LOCATION=path)
  and the only mark seen are messages on standard error like: Can't open perl script ".."
  The reason for the message is that the EPICS installation scripts cannot find some script
  needed and likely its job is not done, resulting in invalid EPICS installation (it doesn't
  stop the installation and can be easily overlooked, unless the standard error is logged).
  The message dosn't tell the script name - seems a variable which is to specify the name
  contains an empty string when it is used and a file of empty name is looked for in the
  parent directory, therefore the name ".." (and later "../..") is in the message.
  I found 2 workarounds for the problem:
  1. Before 'make' copy "src/tools" from source to installation directory (the copy ​has to be
     in "<installation-dir>/src/tools") - the installation looks for the "convertRelease.pl"
     there instead in the "<source-dir>/src/tools".
  2. In the configure/CONFIG_SITE.local add a line "CONVERTRELEASE=<convertRelease.pl-path>";
     I found it also needed setting execute permission for the "convertRelease.pl".
  Unfortunately, I don't know the Perl language and I am unable to make a real fix.
  All this was tried on Linux Ubuntu 18.04 having installed GNU Make 4.1,
  binutils, Perl v5.26.1, perl-modules, GCC/G++ 7.3.0, libreadline-dev.
  Also, I tried it on NI Linux Real-Time 6.0 with the same problem
  (I didn't try the workarounds on the NI Linux yet).
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1932033/+subscriptions
[Bug 1932033] [NEW] base EPICS compilation misses convertRelease.pl Jerzy Tarasiuk via Core-talk
Prev: Build failed in Jenkins: EPICS-7 #354 Jenkins EPICS PSI via Core-talk
Next: [Bug 1932033] Re: base EPICS compilation misses convertRelease.pl Jerzy Tarasiuk via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: [Bug 1932033] Re: base EPICS compilation misses convertRelease.pl Jerzy Tarasiuk via Core-talk
ANJ, 15 Jun 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
