2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1905159] Re: Fix warnings from recent compiler versions
From: Jerzy Tarasiuk via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 16 Jun 2021 15:25:58 -0000
I have tried EPICS base compilation on three different
Ubuntu versions (using LTS = Long Term Support ones only):
Ubuntu 16.04 = GCC and G++ 5.5.0, make 4.1, perl v5.22.1
Ubuntu 18.04 = gcc/g++ 7.3.0, make 4.1, perl v5.26.1
            (there is a gcc 7.5.0 available, but this
             lower version was used for the compilation)
Ubuntu 20.04 = gcc/g++ 9.3.0, make 4.2.1, perl v5.30.0
The base could be compiled on every of them; hoever,
the newer Ubuntu version was used, the more warnings
were produced during the compilation.
I wrote a bug report about warnings showing that some
Perl script could not be fount (it came out that it was
on the beginning of the compilation only and later
the script was used, and it was on every Ubuntu version);
here I am saying about some other warnings I was getting.
One of them was warning about a possibility of buffer
overflow: it was not shown on Ubuntu 16.04, it was shown
for modules/pvAccess/testApp/remote/testServer.cpp
function createNTTable declares char sbuf[16] and uses
a format which can consume more buffer space, at least
theoretically, as the columnsCount is probably small,
so the format may specify %hd instead %d (max=32767).
This warning is shown for Ubuntu 18 and 20, on 18 it is
reported for the first line of the function, on 20 for
the line containing the sprintf.
On all three Ubuntu-s 8 deprecated declarations are
reported.
On the newest only 4 warnings about output truncated
are shown - possibly they are caused by strncpy
(inlined from string.h), however when I tried to get
such a warning from a simple .cpp program, compiling it
using g++ with -Wall -Wstringop-truncation it was not
shown; such a warning are for:
modules/libcom/src/osi/epicsTime.cpp in lines 668 and 680
modules/libcom/src/osi/osiSock.c in line 76
modules/database/src/ioc/dbStatic/dbStaticLib.c in lines
 663, 730 and 745 (one common warning for 3 places - but
 for the last file I do not see the strcpy there - maybe
 functions were inlined and lines are shown incorrectly)
As well as I understand it, such a warning means that
a string used as source for strncpy will _always_ be
truncated (i.e. the compiler predicts it) - sometimes
a string of a length 1 is to be copied without its
terminator and the compiler warns about it!
An alarmistic warning (without a real reason) is shown
for modules/libcom/test/epicsStackTraceTest.c line 96.
The compiles sees that 'sz' gets source length, but
overlooks the fact that it is changed when it exceeds
space in the destination; maybe some change can help?
Unfortunately, when I extracted the code from the EPICS
and compiled it alone, no warning was shown.
Well: to show the warning, I need to use options:
 -O3 -Wall -Werror-implicit-function-declaration
(the last is not needed in this case; -Wpedantic
 and -Wextra can be used, the warning is the same).
Now I tried  the code from the EPICS and some modified
- no luck, I am still getting the warning. The code:
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <ctype.h>
typedef struct { char buf[40]; size_t pos; } TDD, *TestData;
static void logClient(void *ptr, const char *msg)
    TestData td = ptr;
    size_t sz = strlen(msg);
    size_t mx = sizeof(td->buf) - td->pos - 1;
    if ( sz > mx )
        sz = mx;
    strncpy( td->buf+td->pos, msg, sz );
    td->pos += sz;
int main(int argc, char *argv[]) {
  int ai;  TestData td = calloc(sizeof(TDD), 1);
  for (ai=1; ai<argc; ai++) logClient(td, argv[ai]);
  printf("%.*s\n", (int)td->pos, td->buf);
  return 0;
Are we to assume there is a GCC bug?
** Attachment added: "EPICS base compilation warnings for 3 Ubuntu versions"
   https://bugs.launchpad.net/epics-base/+bug/1905159/+attachment/5505042/+files/warnings.zip
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1905159
Title:
Status in EPICS Base:
  Triaged
Bug description:
  Builds of EPICS Base using recent versions of gcc, clang and MSVC
  generate compiler warnings, which we try to minimize if possible. Some
  of these warnings can be prevented with suitable code modifications,
  although the code must still build on the older compilers and other
  architectures that we support.
  Both the 3.15 and 7.0 branches can be examined for warnings; fixes
  made on the 3.15 branch get propagated to the 7.0 branch during
  periodic up-merges, so there is no need to make the same changes to
  both branches. Some code only exists on one branch; for example the
  gdd module was unbundled after 3.15, and there are many new modules in
  7.0.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1905159/+subscriptions
Prev: Build failed: epics-base base-rtems5-dhcp-710 AppVeyor via Core-talk
Next: [Bug 1905159] Re: Fix warnings from recent compiler versions Jerzy Tarasiuk via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: [Bug 1905159] Re: Fix warnings from recent compiler versions Gabriel Fedel via Core-talk
ANJ, 16 Jun 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
