2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1932153] Re: iocsh ignores inline-comment
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 17 Jun 2021 18:14:39 -0000
Unfortunately inline comments like that have never been supported by iocsh. '#' is just treated as another command which does nothing. Comments are documented in
 https://epics.anl.gov/base/R3-15/6-docs/AppDevGuide/IOCShell.html#x19-74000018.2.5
although that doesn't really clarify that inline comments are not supported.
Given the rather complicated way that iocsh processes each command line
I don't know how easy it would be to actually implement such inline
comments. If you were to work on a patch to implement this, please check
that other commands can still accept # characters inside string
parameters – there may be a fundamental problem there given that
parameters don't have to be enclosed inside quotes, this iocsh command
shows the problem:
epics> echo ###-Hello-###
###-Hello-###
** Changed in: epics-base
   Importance: Undecided => Wishlist
       Status: New => Opinion
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1932153
Title:
Status in EPICS Base:
  Opinion
Bug description:
  A function call in iocsh, followed by a comment does not work as
  expected.
  observed behaviour:
  epicsEnvSet("VAR", "0") # set VAR to a very important value. For VAR>42 blah blah
  is creating an empty file named `42` in $PWD.
  expected behaviour:
  All characters after the '#' character should be treated as comment.
  test versions:
  3.14.12 and 7.0.5
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1932153/+subscriptions
[Bug 1932153] [NEW] iocsh ignores inline-comment Niko Kivel via Core-talk
Prev: [Bug 1932120] Re: callbackRequest potentially accesses uninitialized memory Andrew Johnson via Core-talk
Next: [Bug 1932033] Re: base EPICS compilation misses convertRelease.pl Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: [Bug 1932153] [NEW] iocsh ignores inline-comment Niko Kivel via Core-talk
Next: [Bug 1932153] Re: iocsh ignores inline-comment Niko Kivel via Core-talk
ANJ, 17 Jun 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
