2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: Re: Make keeps installing the same files
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: "Rivers, Mark L." <rivers at cars.uchicago.edu>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Tue, 22 Jun 2021 23:33:20 +0000
I also lack understanding of how that could happen; I don’t see anything obvious in the build rules that could trigger it given your tile timestamps. I should have suggested trying make --trace to see what it said, but it’s too late for that now.
- Andrew
On Jun 22, 2021, at 6:08 PM, Mark Rivers <rivers at cars.uchicago.edu> wrote:
Ø  I could come up with some ways that might happen, but none of them would set the timestamps back to mid-May (the dates on your files above), assuming this is the same build area you were demonstrating in your original email and you saw that happening earlier today.
I did not change any code today, so the fact that both files are from mid-May is not surprising.  What I don’t understand is given the timestamps on those files why did “make” say it was installing them, and yet their timestamps in lib/ were old?
I have not restored anything from backups.
Sent: Tuesday, June 22, 2021 6:05 PM
To: Mark Rivers <rivers at cars.uchicago.edu>
On Jun 22, 2021, at 5:42 PM, Mark Rivers <rivers at cars.uchicago.edu> wrote:
Ø  Do any of those libraries contain a version number header which gets recreated and triggers recompilation every time you run the build? It would only take the first-built library to do that and the others would then get re-linked with it as a result.
No, they don’t.
Ø  Are you building this on a local disk, or a file share of some kind? This kind of behavior can happen if the clocks of the two systems are slightly out of sync. Can you ‘ls -l’ a file installed into the lib directory and the same file in the build directory to see if their timestamps are any different.
This is a local disk on the Linux system.
But I see a strange problem.  The file in lib/ is 29 hours newer than the file in the build directory.
corvette:~/devel/areaDetector/ADCore>ls -l --time-style=f lib/linux-x86_64/libADBase.a
-r--r--r-- 1 epics domain users 3050868 2021-05-18 14:44:15.081349713-0500 lib/linux-x86_64/libADBase.a
corvette:~/devel/areaDetector/ADCore>ls -l --time-style=f ADApp/ADSrc/O.linux-x86_64/libADBase.a
-rw-rw-r-- 1 epics domain users 3050868 2021-05-17 09:40:31.599821920-0500 ADApp/ADSrc/O.linux-x86_64/libADBase.a
You haven’t restored any files from backups since then have you?
I did a “make clean” and now I see this.  The file in the lib/ directory is now just a fraction of a second newer than the file in the build directory.  Should they be the exact same time?
-r--r--r-- 1 epics domain users 3050868 2021-06-22 17:37:30.006615685 -0500 lib/linux-x86_64/libADBase.a
-rw-rw-r-- 1 epics domain users 3050868 2021-06-22 17:37:29.658618326 -0500 ADApp/ADSrc/O.linux-x86_64/libADBase.a
It just reported that it was installing the file.  But then the file in lib/ was newer (but not today) than the one in the build folder.
Installing a file does not copy the timestamp from the old file, so the fact that the installed file is a fraction newer than the built one is exactly what I would expect to see. If you run ‘make’ again now without cleaning it or doing anything else, does it still re-do the install or not?
When I do a build like that on a local drive, the time difference I see is of the order 0.05 seconds:
tux% ll --time-style=f libADBase.a ../../../lib/linux-x86_64/libADBase.a
-rw-rw-r-- 1 anj aesctl 277808 2021-06-22 17:59:23.216522107 -0500 libADBase.a
-r--r--r-- 1 anj aesctl 277808 2021-06-22 17:59:23.267522353 -0500 ../../../lib/linux-x86_64/libADBase.a
- Andrew
Sent: Tuesday, June 22, 2021 5:05 PM
Hi Mark,
On Jun 22, 2021, at 4:48 PM, Mark Rivers via Core-talk <core-talk at aps.anl.gov> wrote:
I just noticed something strange.  “make” is installing the same files each time I run it, even though they are already installed.
corvette:~/devel/areaDetector/ADCore>make -sj
Installing library ../../../lib/linux-x86_64/libADBase.a
Installing library ../../../lib/linux-x86_64/libntndArrayConverter.a
Installing library ../../../lib/linux-x86_64/libNDPlugin.a
This is base 7.0.5 on Centos 7.
Also try just running a noisy serial ‘make’ in the first build directory to see what’s actually happening.
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
Make keeps installing the same files Mark Rivers via Core-talk
Re: Make keeps installing the same files Johnson, Andrew N. via Core-talk
RE: Make keeps installing the same files Mark Rivers via Core-talk
Prev: RE: Make keeps installing the same files Mark Rivers via Core-talk
Next: failing tests on vxWorks Zimoch Dirk (PSI) via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
ANJ, 23 Jun 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
