2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1842661] Re: seq record doesn't process LNK0 in "Specified" mode
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sun, 04 Jul 2021 03:19:37 -0000
** Changed in: epics-base
       Status: In Progress => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1842661
Title:
Status in EPICS Base:
  Fix Released
Bug description:
  While updating the seq record reference documentation, we noticed that
  if one tries to use a seq record in "Specified" mode, the LNK0 will
  never be processed, regardless of the OFFS field.
  Possible cause in src/std/rec/seqRecord.c:
          if (prec->selm == seqSELM_Specified) {
              int grpn = prec->seln + prec->offs;
              if (grpn < 0 || grpn >= NUM_LINKS) {
                  recGblSetSevr(prec, SOFT_ALARM, INVALID_ALARM);
                  return asyncFinish(prec);
              if (grpn == 0)
              lmask = 1 << grpn;
  (code from branch 3.15)
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1842661/+subscriptions
Prev: [Bug 1882520] Re: Constant arrary input links of size 1 don't work Andrew Johnson via Core-talk
Next: [Bug 1910148] Re: Broadcast address detection is unreliable on Linux Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: [Bug 788230] Re: Support LP64 data model on vxWorks 6.9 Andrew Johnson via Core-talk
ANJ, 03 Jul 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
