2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 788230] Re: Support LP64 data model on vxWorks 6.9
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sun, 04 Jul 2021 03:23:42 -0000
** Changed in: epics-base
       Status: New => Won't Fix
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/788230
Title:
Status in EPICS Base:
  Won't Fix
Bug description:
  The vxWorks 6.9 release (March 2011) supports some 64-bit Intel CPUs
  with the LP64 data model (i.e. both longs and pointers are 64 bits
  wide).  The libCom/osi/os/vxWorks code will probably not build/work
  properly in this case, it may assume that those are both 32-bit.
  This work is separate and probably simpler than the conversion to
  support SMP on vxWorks.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/788230/+subscriptions
Prev: [Bug 1910148] Re: Broadcast address detection is unreliable on Linux Andrew Johnson via Core-talk
Next: [Bug 1722530] Re: Add userTag to epicsTimeStamp Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: [Bug 1842661] Re: seq record doesn't process LNK0 in "Specified" mode Andrew Johnson via Core-talk
ANJ, 03 Jul 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
