2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1922442] Re: Another race in db_close_events()
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sun, 04 Jul 2021 03:48:11 -0000
** Changed in: epics-base
       Status: New => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1922442
Title:
Status in EPICS Base:
  Fix Released
Bug description:
  Mark Rivers reports a valgrind alert in db_close_events().
  https://epics.anl.gov/core-talk/2021/msg00665.php
  This looks like a race leading to a real use-after-free which is
  being "covered up" by the free list.
  >>> ==146728== Thread 25 CAS-client:
  >>> ==146728== Invalid read of size 8
  >>> ==146728==    at 0xE37113: db_close_events (dbEvent.c:378)
  In dbEvent.c  db_close_events()
  >     /* notify the waiting task */
  >     epicsEventSignal(evUser->ppendsem);
  >     if(evUser->taskid)  // <- line 378
  >         epicsThreadMustJoin(evUser->taskid);
  >     /* evUser has been deleted by the worker */
  Since event_task() is deleting evUser, it looks like everything from the epicsEventSignal()
  onwards is a race.  event_task() also deletes ppendsem, which could happen before
  epicsEventSignal() returns.  So I don't think it would be enough to save 'evUser->taskid'
  before signaling.
  I'm developing a long history with this particular issue.  This being
  the second time I've introduced a similar regression (cf. lp:1730982).
  This time with 37a76b433a9e7d5a8d26a13fd21ad62f20a0c1c1 (in 7.0.3.1).
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1922442/+subscriptions
[Bug 1922442] [NEW] Another race in db_close_events() mdavidsaver via Core-talk
Prev: [Bug 1913699] Re: vxWorks compilation fails with undeclared function Andrew Johnson via Core-talk
Next: Build failed in Jenkins: EPICS-3.14 #1084 Jenkins EPICS PSI via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: [Bug 1922442] Re: Another race in db_close_events() mdavidsaver via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-286 AppVeyor via Core-talk
ANJ, 04 Jul 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
