2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: [Bug 1777768] Re: NPP Put to a pp(TRUE) VAL field doesn't trigger monitors
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Tue, 13 Jul 2021 22:29:56 -0000
Tim Mooney wrote:
> I thought the reason the VAL field was only posted by the record was to give
> the record the ability to refuse a value written to it and not have anyone
> else notified that the value had been written.
That could very well have been the original reasoning, it looks like
puts to the VAL field have behaved like that since the very earliest
commits I have access to (1990).
I now accept that the existing behavior is correct, but it is confusing
to users that DB puts to the VAL field behave differently than to every
other field.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1777768
Title:
Status in EPICS Base:
  Incomplete
Bug description:
  There is code in dbAccess.c::dbPut() that calls db_post_events() after
  writing to a field. This code is conditional, and explicitly avoids
  posting a monitor if the put was to the record's VAL field and that
  field is marked pp(TRUE); if the put came from a CA client the record
  is about to be processed anyway, so this conditional prevents 2
  monitor events from being generated by the same put.
  However if the put was actually from a DB link marked NPP, the above
  logic is wrong because the record is not about to be processed. This
  behavior is somewhat obscure, and does catch out database designers
  (it came up again at APS just today).
  It is possible for the DB link to call db_post_events() itself in this
  case, but it isn't obvious whether it should or not. When I add the
  necessary code the result looks a bit strange because the record's VAL
  changes but the alarm state and timestamp do not. This could also
  conflict with the monitor deadband processing as this monitor will
  happen every time the put occurs and will not update the MLST field.
  I will attach the necessary code changes to this bug report for the
  3.16 branch; earlier branches would need it moving since the
  modifications are to the DB link type, and I don't think it should go
  in any earlier than 3.16 anyhow.
  Opinions please, should this be applied or not?
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1777768/+subscriptions
Prev: Re: [Bug 1777768] Re: NPP Put to a pp(TRUE) VAL field doesn't trigger monitors Mooney, Tim M. via Core-talk
Next: Segmentation fault when Gateway calls ca_clear_channel: removing node from empty createReqPend linked list Paduan Donadio, Marcio via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Next: [Bug 1777768] Re: NPP Put to a pp(TRUE) VAL field doesn't trigger monitors Ralph Lange via Core-talk
ANJ, 14 Jul 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
