2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: Build failed in Jenkins: EPICS-7 #365
From: Jenkins EPICS PSI via Core-talk <core-talk at aps.anl.gov>
To: <dirk.zimoch at psi.ch>, <core-talk at aps.anl.gov>
Date: Tue, 20 Jul 2021 09:55:29 +0200
See <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/365/display/redirect>
[...truncated 4.69 KB...]
patching file configure/os/CONFIG.Common.yocto21-aarch64
patching file configure/os/CONFIG.RHEL7-x86_64.Common
patching file configure/os/CONFIG.RHEL7-x86_64.RHEL7-x86_64
patching file configure/os/CONFIG.RHEL7-x86_64.SL6-x86
patching file configure/os/CONFIG.RHEL7-x86_64.SL6-x86_64
patching file configure/os/CONFIG.RHEL7-x86_64.win32-x86
patching file configure/os/CONFIG.RHEL7-x86_64.windows-x64
patching file configure/os/CONFIG.SL6-x86.Common
patching file configure/os/CONFIG.SL6-x86.SL6-x86
patching file configure/os/CONFIG.SL6-x86_64.Common
patching file configure/os/CONFIG.SL6-x86_64.SL6-x86
patching file configure/os/CONFIG.SL6-x86_64.SL6-x86_64
patching file configure/os/CONFIG_SITE.Common.linuxCommon
patching file configure/os/CONFIG_SITE.Common.vxWorksCommon
patching file configure/os/CONFIG_SITE.RHEL7-x86_64.Common
patching file configure/os/CONFIG_SITE.SL6-x86.Common
patching file configure/os/CONFIG_SITE.SL6-x86_64.Common
patching file configure/os/CONFIG_SITE.linux-x86.Common
patching file configure/os/CONFIG_SITE.linux-x86_64.Common
patching file modules/libcom/src/osi/compiler/gcc/compilerSpecific.h
patching file modules/libcom/src/osi/os/vxWorks/osdThread.c
patching file modules/libcom/test/epicsAtomicTest.cpp
+ export EPICS_HOST_ARCH=RHEL7-x86_64
+ EPICS_HOST_ARCH=RHEL7-x86_64
+ make
make -C ./configure install
make[1]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure'>
perl -CSD ../src/tools/makeMakefile.pl O.RHEL7-x86_64 ../..
perl -CSD ../src/tools/makeMakefile.pl O.T2-ppc604 ../..
perl -CSD ../src/tools/makeMakefile.pl O.V67-ppc604 ../..
perl -CSD ../src/tools/makeMakefile.pl O.V69-ppc604 ../..
perl -CSD ../src/tools/makeMakefile.pl O.V69-ppc32 ../..
perl -CSD ../src/tools/makeMakefile.pl O.V63-ppc603 ../..
perl -CSD ../src/tools/makeMakefile.pl O.mvl40-xscale_be ../..
perl -CSD ../src/tools/makeMakefile.pl O.moxa42-armv6l ../..
perl -CSD ../src/tools/makeMakefile.pl O.eldk51-ppc4xxSF ../..
perl -CSD ../src/tools/makeMakefile.pl O.eldk52-e500v2 ../..
perl -CSD ../src/tools/makeMakefile.pl O.eldk42-ppc4xxFP ../..
perl -CSD ../src/tools/makeMakefile.pl O.eldk53-ppc4xxFP ../..
perl -CSD ../src/tools/makeMakefile.pl O.V66-ppc604 ../..
perl -CSD ../src/tools/makeMakefile.pl O.V64-ppc604 ../..
perl -CSD ../src/tools/makeMakefile.pl O.V62-ppc604 ../..
perl -CSD ../src/tools/makeMakefile.pl O.raspbian-arm ../..
perl -CSD ../src/tools/makeMakefile.pl O.fslqoriq20-e6500_64 ../..
perl -CSD ../src/tools/makeMakefile.pl O.yocto21-aarch64 ../..
perl -CSD ../src/tools/makeMakefile.pl O.RHEL7-x86_64-clang ../..
perl -CSD ../src/tools/makeMakefile.pl O.SL6-x86_64 ../..
perl -CSD ../src/tools/makeMakefile.pl O.nilrt7-armv7a ../..
perl -CSD ../src/tools/makeMakefile.pl O.win32-x86 ../..
perl -CSD ../src/tools/makeMakefile.pl O.windows-x64 ../..
mkdir -p O.Common
make -C O.RHEL7-x86_64 -f ../Makefile TOP=../.. \
    T_A=RHEL7-x86_64 install
make[2]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.RHEL7-x86_64'>
/usr/bin/gcc -x c -E  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include         ../toolchain.c > TOOLCHAIN.RHEL7-x86_64.RHEL7-x86_64
Installing CFG file ../../cfg/TOOLCHAIN.RHEL7-x86_64.RHEL7-x86_64
mkdir ../../cfg
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.RHEL7-x86_64'>
Installing CFG file ../../cfg/CONFIG_LIBCOM_MODULE
Installing CFG file ../../cfg/CONFIG_LIBCOM_VERSION
Installing CFG file ../../cfg/CONFIG_CA_MODULE
Installing CFG file ../../cfg/CONFIG_CA_VERSION
Installing CFG file ../../cfg/CONFIG_DATABASE_MODULE
Installing CFG file ../../cfg/CONFIG_DATABASE_VERSION
make -C O.T2-ppc604 -f ../Makefile TOP=../.. \
    T_A=T2-ppc604 install
make[2]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.T2-ppc604'>
/afs/psi.ch/project/vxworks/Tornado2.2.1/host/x86-linux2/bin/ccppc -x c -E -isystem /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h -DCPU=PPC604 -DvxWorks=vxWorks -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/vxWorks -I../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h ../toolchain.c > TOOLCHAIN.RHEL7-x86_64.T2-ppc604
Installing CFG file ../../cfg/TOOLCHAIN.RHEL7-x86_64.T2-ppc604
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.T2-ppc604'>
make[2]: Nothing to be done for `install'.
make -C O.V67-ppc604 -f ../Makefile TOP=../.. \
    T_A=V67-ppc604 install
make[2]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.V67-ppc604'>
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -x c -E -isystem /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -DCPU=PPC604 -DvxWorks=vxWorks -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/vxWorks -I../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip ../toolchain.c > TOOLCHAIN.RHEL7-x86_64.V67-ppc604
Installing CFG file ../../cfg/TOOLCHAIN.RHEL7-x86_64.V67-ppc604
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.V67-ppc604'>
make -C O.V69-ppc604 -f ../Makefile TOP=../.. \
    T_A=V69-ppc604 install
make[2]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.V69-ppc604'>
/afs/psi.ch/project/vxworks/VxWorks6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc -x c -E -isystem /afs/psi.ch/project/vxworks/VxWorks6.9/vxworks-6.9/target/h -DCPU=PPC604 -DvxWorks=vxWorks -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/vxWorks -I../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.9/vxworks-6.9/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.9/vxworks-6.9/target/h/wrn/coreip ../toolchain.c > TOOLCHAIN.RHEL7-x86_64.V69-ppc604
Installing CFG file ../../cfg/TOOLCHAIN.RHEL7-x86_64.V69-ppc604
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.V69-ppc604'>
make -C O.V69-ppc32 -f ../Makefile TOP=../.. \
    T_A=V69-ppc32 install
make[2]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.V69-ppc32'>
/afs/psi.ch/project/vxworks/VxWorks6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc -x c -E -isystem /afs/psi.ch/project/vxworks/VxWorks6.9/vxworks-6.9/target/h -DCPU=PPC32 -DvxWorks=vxWorks -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/vxWorks -I../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.9/vxworks-6.9/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.9/vxworks-6.9/target/h/wrn/coreip ../toolchain.c > TOOLCHAIN.RHEL7-x86_64.V69-ppc32
Installing CFG file ../../cfg/TOOLCHAIN.RHEL7-x86_64.V69-ppc32
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.V69-ppc32'>
make -C O.V63-ppc603 -f ../Makefile TOP=../.. \
    T_A=V63-ppc603 install
make[2]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.V63-ppc603'>
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -x c -E -isystem /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -DCPU=PPC603 -DvxWorks=vxWorks -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/vxWorks -I../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip ../toolchain.c > TOOLCHAIN.RHEL7-x86_64.V63-ppc603
Installing CFG file ../../cfg/TOOLCHAIN.RHEL7-x86_64.V63-ppc603
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.V63-ppc603'>
make -C O.mvl40-xscale_be -f ../Makefile TOP=../.. \
    T_A=mvl40-xscale_be install
make[2]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.mvl40-xscale_be'>
/afs/psi.ch/project/embeddedlinux/moxa/xscale_be/armv5teb-montavista-linuxeabi/bin/gcc -x c -E  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux  -fno-strict-aliasing  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include         ../toolchain.c > TOOLCHAIN.RHEL7-x86_64.mvl40-xscale_be
Installing CFG file ../../cfg/TOOLCHAIN.RHEL7-x86_64.mvl40-xscale_be
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.mvl40-xscale_be'>
make -C O.moxa42-armv6l -f ../Makefile TOP=../.. \
    T_A=moxa42-armv6l install
make[2]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.moxa42-armv6l'>
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-gcc -x c -E  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux  -fno-strict-aliasing  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include         ../toolchain.c > TOOLCHAIN.RHEL7-x86_64.moxa42-armv6l
Installing CFG file ../../cfg/TOOLCHAIN.RHEL7-x86_64.moxa42-armv6l
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.moxa42-armv6l'>
make -C O.eldk51-ppc4xxSF -f ../Makefile TOP=../.. \
    T_A=eldk51-ppc4xxSF install
make[2]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.eldk51-ppc4xxSF'>
/opt/eldk-5.1/powerpc-4xx-softfloat/sysroots/i686-eldk-linux/usr/bin/ppc405-linux/powerpc-4xx-softfloat-gcc -x c -E  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux  -fno-strict-aliasing  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include         ../toolchain.c > TOOLCHAIN.RHEL7-x86_64.eldk51-ppc4xxSF
Installing CFG file ../../cfg/TOOLCHAIN.RHEL7-x86_64.eldk51-ppc4xxSF
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.eldk51-ppc4xxSF'>
make -C O.eldk52-e500v2 -f ../Makefile TOP=../.. \
    T_A=eldk52-e500v2 install
make[2]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.eldk52-e500v2'>
/opt/eldk-5.2/powerpc-e500v2/sysroots/i686-eldk-linux/usr/bin/ppce500v2-linux-gnuspe/powerpc-e500v2-gcc -x c -E  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux  -fno-strict-aliasing  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include         ../toolchain.c > TOOLCHAIN.RHEL7-x86_64.eldk52-e500v2
Installing CFG file ../../cfg/TOOLCHAIN.RHEL7-x86_64.eldk52-e500v2
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.eldk52-e500v2'>
make -C O.eldk42-ppc4xxFP -f ../Makefile TOP=../.. \
    T_A=eldk42-ppc4xxFP install
make[2]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.eldk42-ppc4xxFP'>
/opt/eldk-4.2/usr/bin/ppc_4xxFP-gcc -x c -E  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux  -fno-strict-aliasing  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include         ../toolchain.c > TOOLCHAIN.RHEL7-x86_64.eldk42-ppc4xxFP
Installing CFG file ../../cfg/TOOLCHAIN.RHEL7-x86_64.eldk42-ppc4xxFP
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.eldk42-ppc4xxFP'>
make -C O.eldk53-ppc4xxFP -f ../Makefile TOP=../.. \
    T_A=eldk53-ppc4xxFP install
make[2]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.eldk53-ppc4xxFP'>
/opt/eldk-5.3/powerpc-4xx/sysroots/i686-eldk-linux/usr/bin/ppc440e-linux/powerpc-linux-gcc -x c -E  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -m32 -mcpu=440fp -mhard-float --sysroot=/opt/eldk-5.3/powerpc-4xx/sysroots/ppc440e-linux  -DUNIX  -Dlinux  -fno-strict-aliasing  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include         ../toolchain.c > TOOLCHAIN.RHEL7-x86_64.eldk53-ppc4xxFP
Installing CFG file ../../cfg/TOOLCHAIN.RHEL7-x86_64.eldk53-ppc4xxFP
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.eldk53-ppc4xxFP'>
make -C O.V66-ppc604 -f ../Makefile TOP=../.. \
    T_A=V66-ppc604 install
make[2]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.V66-ppc604'>
/afs/psi.ch/project/vxworks/VxWorks6.6/gnu/4.1.2-vxworks-6.6/x86-linux2/bin/ccppc -x c -E -isystem /afs/psi.ch/project/vxworks/VxWorks6.6/vxworks-6.6/target/h -DCPU=PPC604 -DvxWorks=vxWorks -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/vxWorks -I../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.6/vxworks-6.6/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.6/vxworks-6.6/target/h/wrn/coreip ../toolchain.c > TOOLCHAIN.RHEL7-x86_64.V66-ppc604
Installing CFG file ../../cfg/TOOLCHAIN.RHEL7-x86_64.V66-ppc604
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.V66-ppc604'>
make -C O.V64-ppc604 -f ../Makefile TOP=../.. \
    T_A=V64-ppc604 install
make[2]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.V64-ppc604'>
/afs/psi.ch/project/vxworks/VxWorks6.4/gnu/3.4.4-vxworks-6.4/x86-linux2/bin/ccppc -x c -E -isystem /afs/psi.ch/project/vxworks/VxWorks6.4/vxworks-6.4/target/h -DCPU=PPC604 -DvxWorks=vxWorks -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/vxWorks -I../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.4/vxworks-6.4/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.4/vxworks-6.4/target/h/wrn/coreip ../toolchain.c > TOOLCHAIN.RHEL7-x86_64.V64-ppc604
Installing CFG file ../../cfg/TOOLCHAIN.RHEL7-x86_64.V64-ppc604
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.V64-ppc604'>
make -C O.V62-ppc604 -f ../Makefile TOP=../.. \
    T_A=V62-ppc604 install
make[2]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.V62-ppc604'>
/afs/psi.ch/project/vxworks/VxWorks6.2/gnu/3.3.2-vxworks-6.2/x86-linux2/bin/ccppc -x c -E -isystem /afs/psi.ch/project/vxworks/VxWorks6.2/vxworks-6.2/target/h -DCPU=PPC604 -DvxWorks=vxWorks -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/vxWorks -I../../include        -I/afs/psi.ch/project/vxworks/VxWorks6.2/vxworks-6.2/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.2/vxworks-6.2/target/h/wrn/coreip ../toolchain.c > TOOLCHAIN.RHEL7-x86_64.V62-ppc604
Installing CFG file ../../cfg/TOOLCHAIN.RHEL7-x86_64.V62-ppc604
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.V62-ppc604'>
make -C O.raspbian-arm -f ../Makefile TOP=../.. \
    T_A=raspbian-arm install
make[2]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.raspbian-arm'>
/opt/raspberrypi/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/arm-linux-gnueabihf-gcc -x c -E  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux  -fno-strict-aliasing  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include        -I/opt/raspberrypi/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/arm-linux-gnueabihf/include ../toolchain.c > TOOLCHAIN.RHEL7-x86_64.raspbian-arm
Installing CFG file ../../cfg/TOOLCHAIN.RHEL7-x86_64.raspbian-arm
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.raspbian-arm'>
make -C O.fslqoriq20-e6500_64 -f ../Makefile TOP=../.. \
    T_A=fslqoriq20-e6500_64 install
make[2]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.fslqoriq20-e6500_64'>
/opt/fsl-qoriq/2.0/sysroots/x86_64-fslsdk-linux/usr/bin/powerpc64-fsl-linux/powerpc64-fsl-linux-gcc -x c -E  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/fsl-qoriq/2.0/sysroots/ppc64e6500-fsl-linux  -DUNIX  -Dlinux  -fno-strict-aliasing  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include         ../toolchain.c > TOOLCHAIN.RHEL7-x86_64.fslqoriq20-e6500_64
Installing CFG file ../../cfg/TOOLCHAIN.RHEL7-x86_64.fslqoriq20-e6500_64
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.fslqoriq20-e6500_64'>
make -C O.yocto21-aarch64 -f ../Makefile TOP=../.. \
    T_A=yocto21-aarch64 install
make[2]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.yocto21-aarch64'>
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc -x c -E  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux  -fno-strict-aliasing  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include         ../toolchain.c > TOOLCHAIN.RHEL7-x86_64.yocto21-aarch64
Installing CFG file ../../cfg/TOOLCHAIN.RHEL7-x86_64.yocto21-aarch64
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.yocto21-aarch64'>
make -C O.RHEL7-x86_64-clang -f ../Makefile TOP=../.. \
    T_A=RHEL7-x86_64-clang install
make[2]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.RHEL7-x86_64-clang'>
clang -x c -E  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux  -fno-strict-aliasing  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/clang -I../../include/os/Linux -I../../include         ../toolchain.c > TOOLCHAIN.RHEL7-x86_64.RHEL7-x86_64-clang
Installing CFG file ../../cfg/TOOLCHAIN.RHEL7-x86_64.RHEL7-x86_64-clang
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.RHEL7-x86_64-clang'>
make -C O.SL6-x86_64 -f ../Makefile TOP=../.. \
    T_A=SL6-x86_64 install
make[2]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.SL6-x86_64'>
/usr/bin/gcc44 -x c -E  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include    -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include         ../toolchain.c > TOOLCHAIN.RHEL7-x86_64.SL6-x86_64
Installing CFG file ../../cfg/TOOLCHAIN.RHEL7-x86_64.SL6-x86_64
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.SL6-x86_64'>
make -C O.nilrt7-armv7a -f ../Makefile TOP=../.. \
    T_A=nilrt7-armv7a install
make[2]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.nilrt7-armv7a'>
/usr/bin/arm-linux-gnu-gcc -x c -E  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -march=armv7-a -mthumb-interwork -mfloat-abi=softfp -mfpu=neon --sysroot=/opt/LabVIEW-RT-19.5.1/arm/sysroots/armv7a-vfp-neon-nilrt-linux-gnueabi -I/opt/LabVIEW-RT-19.5.1/arm/sysroots/armv7a-vfp-neon-nilrt-linux-gnueabi/usr/include/c++/4.7.2/arm-nilrt-linux-gnueabi/ -I/opt/LabVIEW-RT-19.5.1/arm/sysroots/armv7a-vfp-neon-nilrt-linux-gnueabi/usr/include/c++/4.7.2/  -DUNIX  -Dlinux  -fno-strict-aliasing  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include         ../toolchain.c > TOOLCHAIN.RHEL7-x86_64.nilrt7-armv7a
/bin/sh: /usr/bin/arm-linux-gnu-gcc: No such file or directory
make[2]: *** No rule to make target `TOOLCHAIN.RHEL7-x86_64.nilrt7-armv7a', needed by `../../cfg/TOOLCHAIN.RHEL7-x86_64.nilrt7-armv7a'.  Stop.
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure/O.nilrt7-armv7a'>
make[1]: *** [install.nilrt7-armv7a] Error 2
make[1]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/configure'>
make: *** [configure.install] Error 2
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: EPICS-7 #366 Jenkins EPICS PSI via Core-talk
Build failed in Jenkins: EPICS-7 #364 Jenkins EPICS PSI via Core-talk
Prev: Build failed in Jenkins: EPICS-3.14 #1098 Jenkins EPICS PSI via Core-talk
Next: Build failed in Jenkins: EPICS-7 #366 Jenkins EPICS PSI via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: Build failed in Jenkins: EPICS-7 #364 Jenkins EPICS PSI via Core-talk
ANJ, 20 Jul 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
