Just tried that, and it fixes the issue that I saw. Will try to create a
PR on GitHub
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1938459
Title:
int64in only checks lower 32 bits for change
Status in EPICS Base:
New
Bug description:
Create an int64in record and write these values
(example uses bash to convert hex into decimal since caput cannot directly handle hex?):
caput sixtyfour $(( 16#FF ))
Old : sixtyfour 0
New : sixtyfour 255
caput sixtyfour $(( 16#87654321 ))
Old : sixtyfour 255
New : sixtyfour 2.27156e+09
caput sixtyfour $(( 16#32187654321 ))
Old : sixtyfour 2.27156e+09
New : sixtyfour 3.44254e+12
A camonitor will show 255, then 2.27156e+09, but not 3.44254e+12. A
caget or a newly started camonitor will see the latest value.
Reason is this section in int64inRecord.c:
/* DELTA calculates the absolute difference between its arguments
* expressed as an unsigned 32-bit integer */
#define DELTA(last, val) \
((epicsUInt32) ((last) > (val) ? (last) - (val) : (val) - (last)))
It only checks for changes in the lower 32 bits of the value.
Maybe the motivation was to always perform an _unsigned_ comparison, but "UInt32" was copy/pasted instead of "UInt64"?
One fix should be to replace epicsUInt32 with epicsUInt64 in DELTA and
where it's used.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1938459/+subscriptions
- [Bug 1938459] [NEW] int64in only checks lower 32 bits for change kasemir via Core-talk
Jenkins build is back to normal : EPICS-3.14 #1109 Jenkins EPICS PSI via Core-talk
[Bug 1938459] Re: int64in only checks lower 32 bits for change kasemir via Core-talk
<2021>
2025
2026
[Bug 1938459] Re: int64in only checks lower 32 bits for change mdavidsaver via Core-talk
<2021>
2025
2026
