> One fix should be to replace epicsUInt32 with epicsUInt64 in DELTA and
where it's used.
Can you try replacing all three mentions of 'epicsUInt32' with
'epicsUInt64'?
It looks like int64outRecord.c is correct.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1938459
Title:
int64in only checks lower 32 bits for change
Status in EPICS Base:
New
Bug description:
Create an int64in record and write these values
(example uses bash to convert hex into decimal since caput cannot directly handle hex?):
caput sixtyfour $(( 16#FF ))
Old : sixtyfour 0
New : sixtyfour 255
caput sixtyfour $(( 16#87654321 ))
Old : sixtyfour 255
New : sixtyfour 2.27156e+09
caput sixtyfour $(( 16#32187654321 ))
Old : sixtyfour 2.27156e+09
New : sixtyfour 3.44254e+12
A camonitor will show 255, then 2.27156e+09, but not 3.44254e+12. A
caget or a newly started camonitor will see the latest value.
Reason is this section in int64inRecord.c:
/* DELTA calculates the absolute difference between its arguments
* expressed as an unsigned 32-bit integer */
#define DELTA(last, val) \
((epicsUInt32) ((last) > (val) ? (last) - (val) : (val) - (last)))
It only checks for changes in the lower 32 bits of the value.
Maybe the motivation was to always perform an _unsigned_ comparison, but "UInt32" was copy/pasted instead of "UInt64"?
where it's used.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1938459/+subscriptions
- [Bug 1938459] [NEW] int64in only checks lower 32 bits for change kasemir via Core-talk
Jenkins build is back to normal : EPICS-3.14 #1109 Jenkins EPICS PSI via Core-talk
<2021>
2025
2026
[Bug 1938459] Re: int64in only checks lower 32 bits for change kasemir via Core-talk
<2021>
2025
2026
