2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: [Bug 1935037] Re: Invalid charactor in field name
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 26 Aug 2021 17:29:43 -0000
Also, I've taken advantage of this restriction with PVXS to allow an
extended syntax for traversing into structures, unions, and arrays.  eg.
> pvxs::Value top;
> top["value[5]->ufld1"] = ...
This takes a 'top' Structure, traverses to the 'value' field, which is
an array of Unions.  Then indexing the 5th element, and then
accessing/selecting the 'ufld1' member of the Union.
Right now my parsing doesn't handle a Structure field named "in-valid",
although it could (no following '>').
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1935037
Title:
Status in EPICS Base:
  New
Bug description:
  When creating a group in QSRV, the allowed characters are too
  restrictive
  error:
  Error Group not created: Invalid charactor '-' (45) in field name "BI02-TimeRise" must be A-Z, a-z, 0-9, or '_'
  expected behaviour:
  pva structures should allow for a more liberal set of characters that just what is covered by \w regex metacharacter.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1935037/+subscriptions
[Bug 1935037] [NEW] Invalid charactor in field name Niko Kivel via Core-talk
Prev: [Bug 1941770] [NEW] Base-3.15.9 tarfile is missing the startup directory Andrew Johnson via Core-talk
Next: Re: [Bug 1935037] Re: Invalid charactor in field name Niko Kivel via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: Re: [Bug 1935037] Re: Invalid charactor in field name Niko Kivel via Core-talk
Next: [Bug 1935037] Re: Invalid charactor in field name Dirk Zimoch via Core-talk
ANJ, 27 Aug 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
