2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: Building base 7.0.6 with parallel make fails on windows-x64
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: EPICS core-talk <core-talk at aps.anl.gov>
Date: Sat, 11 Sep 2021 14:02:34 +0000
I tried to build base 7.0.6 on windows-x64 using “make –sj8” on an 8-core machine.  It failed as follows:
softIoc_registerRecordDeviceDriver.cpp
softMain.cpp
   Creating library dbRecStd.lib and object dbRecStd.exp
Generating code
Finished generating code
Generating code
dbdExpand.pl: Can't find file 'dbCommon.dbd'
  while reading 'base.dbd' to create 'recTestIoc.dbd'
dbdExpand.pl: Exiting due to errors
make[5]: *** [../../../../../../configure/RULES.Db:403: ../O.Common/recTestIoc.dbd] Error 2
make[5]: *** Waiting for unfinished jobs....
make[4]: *** [../../../../../configure/RULES_ARCHS:58: install.windows-x64] Error 2
make[3]: *** [../../../configure/RULES_DIRS:85: std/rec.install] Error 2
make[3]: *** Waiting for unfinished jobs....
ioRecord.c
lnkStateTest.c
I did not see any others before that one.
Running make –sj8 again appeared to work although it started with this message:
H:\epics-devel\base-7.0.6>make -sj8
'..' is not recognized as an internal or external command,
operable program or batch file.
asTestLib.c
dbHeaderTest.c
arrayOpTest.c
Re: Building base 7.0.6 with parallel make fails on windows-x64 Johnson, Andrew N. via Core-talk
Prev: Build failed: pva2pva 1.0.41 AppVeyor via Core-talk
Next: Build failed: pva2pva 1.0.42 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Next: Re: Building base 7.0.6 with parallel make fails on windows-x64 Johnson, Andrew N. via Core-talk
ANJ, 15 Sep 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
