Build URL: https://jenkins.aps.anl.gov/job/epics-7.0/OS=linux32/361/ This job built successfully, but has failing tests. Target summary: [...truncated 5176 lines...] Tests failed in:
modules/pva2pva/testApp/O.linux-x86
testpvalink.tap
configure/RULES_TOP:55: recipe for target 'test-results' failed
make: *** [test-results] Error 1
+ exit 255
Build step 'Execute shell' changed build result to UNSTABLE
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: **/O.*/*.tap
Saving reports...
There are failed test cases. Marking build as UNSTABLE
TAP Reports Processing: FINISH
Notifying upstream projects of job completion
Email was triggered for: Unstable (Test Failures)
Sending email for trigger: Unstable (Test Failures)
| ANJ, 26 Sep 2021 |
Home
News
About
Talk
Base
Modules
Extensions
