2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: epics-7.0 » linux32 - Build # 362 - Still Unstable!
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sun, 26 Sep 2021 00:00:59 -0500 (CDT)
Build URL: https://jenkins.aps.anl.gov/job/epics-7.0/OS=linux32/362/
This job built successfully, but has failing tests.
Target summary:
[...truncated 5180 lines...]
Tests failed in:
    modules/database/test/std/rec/O.linux-x86
        regressTest.tap
configure/RULES_TOP:55: recipe for target 'test-results' failed
make: *** [test-results] Error 1
+ exit 255
Build step 'Execute shell' changed build result to UNSTABLE
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: **/O.*/*.tap
Saving reports...
There are failed test cases. Marking build as UNSTABLE
TAP Reports Processing: FINISH
Notifying upstream projects of job completion
Email was triggered for: Unstable (Test Failures)
Sending email for trigger: Unstable (Test Failures)
epics-7.0 » linux32 - Build # 363 - Fixed! APS Jenkins via Core-talk
epics-7.0 » linux32 - Build # 361 - Still Unstable! APS Jenkins via Core-talk
Prev: epics-7.0 » mac - Build # 362 - Failure! APS Jenkins via Core-talk
Next: [Bug 1945454] [NEW] Callback queue overflows are not reported Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: epics-7.0 » linux32 - Build # 361 - Still Unstable! APS Jenkins via Core-talk
Next: epics-7.0 » linux32 - Build # 363 - Fixed! APS Jenkins via Core-talk
ANJ, 01 Oct 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
