Build URL: https://jenkins.aps.anl.gov/job/epics-7.0/OS=mac/362/ This job failed to build. Started by upstream project "epics-7.0" build number 362 originally caused by: Started by an SCM change Running as SYSTEM [EnvInject] - Loading node environment variables. Building remotely on mac-1 (mac) in workspace /Users/jenkins/workspace/epics-7.0/OS/mac The recommended git tool is: NONE No credentials specified > git rev-parse --resolve-git-dir /Users/jenkins/workspace/epics-7.0/OS/mac/.git # timeout=10 Fetching changes from the remote Git repository > git config remote.origin.url https://git.launchpad.net/epics-base/ # timeout=10 Fetching upstream changes from https://git.launchpad.net/epics-base/ > git --version # timeout=10 > git --version # 'git version 2.21.1 (Apple Git-122.3)' Setting http proxy: webproxy1.anl.gov:9091 > git fetch --tags --force --progress -- https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/* # timeout=10 ERROR: Error fetching remote repo 'origin' hudson.plugins.git.GitException: Failed to fetch from https://git.launchpad.net/epics-base/ at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:1004) at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1245) at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1305) at hudson.scm.SCM.checkout(SCM.java:505) at hudson.model.AbstractProject.checkout(AbstractProject.java:1213) at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:639) at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86) at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:511) at hudson.model.Run.execute(Run.java:1889) at hudson.matrix.MatrixRun.run(MatrixRun.java:153) at hudson.model.ResourceController.execute(ResourceController.java:100) at hudson.model.Executor.run(Executor.java:433) Caused by: hudson.plugins.git.GitException: Command "git fetch --tags --force --progress -- https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/*" returned status code 1: stdout: stderr: remote: Enumerating objects: 59, done. remote: Counting objects: 1% (1/59) remote: Counting objects: 3% (2/59) remote: Counting objects: 5% (3/59) remote: Counting objects: 6% (4/59) remote: Counting objects: 8% (5/59) remote: Counting objects: 10% (6/59) remote: Counting objects: 11% (7/59) remote: Counting objects: 13% (8/59) remote: Counting objects: 15% (9/59) remote: Counting objects: 16% (10/59) remote: Counting objects: 18% (11/59) remote: Counting objects: 20% (12/59) remote: Counting objects: 22% (13/59) remote: Counting objects: 23% (14/59) remote: Counting objects: 25% (15/59) remote: Counting objects: 27% (16/59) remote: Counting objects: 28% (17/59) remote: Counting objects: 30% (18/59) remote: Counting objects: 32% (19/59) remote: Counting objects: 33% (20/59) remote: Counting objects: 35% (21/59) remote: Counting objects: 37% (22/59) remote: Counting objects: 38% (23/59) remote: Counting objects: 40% (24/59) remote: Counting objects: 42% (25/59) remote: Counting objects: 44% (26/59) remote: Counting objects: 45% (27/59) remote: Counting objects: 47% (28/59) remote: Counting objects: 49% (29/59) remote: Counting objects: 50% (30/59) remote: Counting objects: 52% (31/59) remote: Counting objects: 54% (32/59) remote: Counting objects: 55% (33/59) remote: Counting objects: 57% (34/59) remote: Counting objects: 59% (35/59) remote: Counting objects: 61% (36/59) remote: Counting objects: 62% (37/59) remote: Counting objects: 64% (38/59) remote: Counting objects: 66% (39/59) remote: Counting objects: 67% (40/59) remote: Counting objects: 69% (41/59) remote: Counting objects: 71% (42/59) remote: Counting objects: 72% (43/59) remote: Counting objects: 74% (44/59) remote: Counting objects: 76% (45/59) remote: Counting objects: 77% (46/59) remote: Counting objects: 79% (47/59) remote: Counting objects: 81% (48/59) remote: Counting objects: 83% (49/59) remote: Counting objects: 84% (50/59) remote: Counting objects: 86% (51/59) remote: Counting objects: 88% (52/59) remote: Counting objects: 89% (53/59) remote: Counting objects: 91% (54/59) remote: Counting objects: 93% (55/59) remote: Counting objects: 94% (56/59) remote: Counting objects: 96% (57/59) remote: Counting objects: 98% (58/59) remote: Counting objects: 100% (59/59) remote: Counting objects: 100% (59/59), done. remote: Compressing objects: 2% (1/36) remote: Compressing objects: 5% (2/36) remote: Compressing objects: 8% (3/36) remote: Compressing objects: 11% (4/36) remote: Compressing objects: 13% (5/36) remote: Compressing objects: 16% (6/36) remote: Compressing objects: 19% (7/36) remote: Compressing objects: 22% (8/36) remote: Compressing objects: 25% (9/36) remote: Compressing objects: 27% (10/36) remote: Compressing objects: 30% (11/36) remote: Compressing objects: 33% (12/36) remote: Compressing objects: 36% (13/36) remote: Compressing objects: 38% (14/36) remote: Compressing objects: 41% (15/36) remote: Compressing objects: 44% (16/36) remote: Compressing objects: 47% (17/36) remote: Compressing objects: 50% (18/36) remote: Compressing objects: 52% (19/36) remote: Compressing objects: 55% (20/36) remote: Compressing objects: 58% (21/36) remote: Compressing objects: 61% (22/36) remote: Compressing objects: 63% (23/36) remote: Compressing objects: 66% (24/36) remote: Compressing objects: 69% (25/36) remote: Compressing objects: 72% (26/36) remote: Compressing objects: 75% (27/36) remote: Compressing objects: 77% (28/36) remote: Compressing objects: 80% (29/36) remote: Compressing objects: 83% (30/36) remote: Compressing objects: 86% (31/36) remote: Compressing objects: 88% (32/36) remote: Compressing objects: 91% (33/36) remote: Compressing objects: 94% (34/36) remote: Compressing objects: 97% (35/36) remote: Compressing objects: 100% (36/36) remote: Compressing objects: 100% (36/36), done. remote: Total 36 (delta 29), reused 0 (delta 0) From https://git.launchpad.net/epics-base 3d09106b5..66ff5a7bb 7.0 -> origin/7.0 Fetching submodule modules/pvAccess From https://github.com/epics-base/pvAccessCPP 7240f97..75e3d9e master -> origin/master Could not access submodule '.ci' at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2681) at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:2102) at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$500(CliGitAPIImpl.java:86) at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:624) at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$GitCommandMasterToSlaveCallable.call(RemoteGitImpl.java:160) at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$GitCommandMasterToSlaveCallable.call(RemoteGitImpl.java:153) at hudson.remoting.UserRequest.perform(UserRequest.java:211) at hudson.remoting.UserRequest.perform(UserRequest.java:54) at hudson.remoting.Request$2.run(Request.java:376) at hudson.remoting.InterceptingExecutorService.lambda$wrap$0(InterceptingExecutorService.java:78) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748) Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to mac-1 at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1795) at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:356) at hudson.remoting.Channel.call(Channel.java:1001) at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:145) at sun.reflect.GeneratedMethodAccessor927.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:131) at com.sun.proxy.$Proxy93.execute(Unknown Source) at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:1002) at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1245) at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1305) at hudson.scm.SCM.checkout(SCM.java:505) at hudson.model.AbstractProject.checkout(AbstractProject.java:1213) at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:639) at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86) at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:511) at hudson.model.Run.execute(Run.java:1889) at hudson.matrix.MatrixRun.run(MatrixRun.java:153) at hudson.model.ResourceController.execute(ResourceController.java:100) at hudson.model.Executor.run(Executor.java:433) ERROR: Error fetching remote repo 'origin' TAP Reports Processing: START Looking for TAP results report in workspace using pattern: **/O.*/*.tap Saving reports... TAP Reports Processing: FINISH Notifying upstream projects of job completion Email was triggered for: Failure - Any Sending email for trigger: Failure - Any Sending email to: core-talk at aps.anl.gov
| ANJ, 01 Oct 2021 |
Home
News
About
Talk
Base
Modules
Extensions
